Results 1 to 4 of 4
Thread: Honda cg 125 engine overheating
    moon12's Avatar
    Aug 2012
    Default Honda cg 125 engine overheating
    I have 2014 cg 125, Recently i face dim head lite problem, electrician said need to replace rectifier so after replacing i face another issue, after 4 to 5 km bike engine stops and when i kick again there is huge backfire, but after some time (i think when engine get cool little bit) bike starts and run 2-3 km and stops with same problem well again electrician said now there may b a problem with magnet (ghocha) wires after change that bike runs 10 km and same problem i have face,engine stops and backfire when kick again
    kindly share ur experience regarding this
    Muddasir's Avatar
    Apr 2004
    29
    25
    I had somewhat similar issues with my CG125, it turned out that my CDI was the culprit here and I got it changed and since then its fine! Try getting an input on your CID, if the bike magnet, and wires and all have been checked and verified then mostly CID would have an issue!
    muhammedahmed2's Avatar
    Jul 2014
    Rawalpindi
    18
    406
    6 Post(s)
    same prob with me and after changed cdi prob was solved...
    bike_freak's Avatar
    Apr 2009
    24
    26
    Change the C.D.I,spark plug and the charger
