Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 47
Like Tree15Likes
Thread: help me honda 125 engine is very heat up
    kamoojan's Avatar
    Mar 2014
    34
    Default help me honda 125 engine is very heat up
    aoa
    mayre pass honda 125 2012 hai mayre bike ka engine buhad jaldi gram ho jata hai ar kuch runing k baad tu buhad he zada koi mujy ye betaye k kya prb hai ya kya cheez may change kro k bike ka engine normal heat up ho.heat is had tak barr jate hai k break paindle per pair rhakna mushkil ho jata hai buhad heat mahsoos hote hai bike se.
  2. #21
    murtaza.khanzada20's Avatar
    Dec 2013
    Hyderabad
    23
    71
    Saboor. Bro jo hm usko bata rahy hen wo ye bat mechanic ko bata raha hai. .ap bhi ye bat samajhty hen k mechanic ko kis language mai samjhana hota hai. Phr bhi my bad
    Sent from my A5Classic using Tapatalk
  3. #22
    Dec 2013
    Hyderabad
    23
    71
    Matlab full necha dikhany ka program hai bhae yahan tou Xulfiqar bhai ka. Abviously combustion chamber mai ..
  4. #23
    Dec 2013
    Hyderabad
    23
    71
    Alryt bro. Hm yahan sikhny or sikhany k liye hen. Na k kisi ko necha dikhany k liyee. So chill . Aftari ka time hogya hai ab roza kholty hen
  5. #24
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    its an extremely simple engine to sort out. If the pump is suspect the usual culprits are hard O rings at the back of it. You can also remove and polish the pump housing to make it like new again.
    Next is to clean the centrifugal filter mounted on the primary drive gear (rarely seen local mechanics cleaning it). The lower rockers are inspected with bore guage and micrometer on pin. If the engine suffered from any bad oil incident or overheat.
    The valve seat margin is of great importance here, it should be atleast 2mm wide and equal on all sides. Ultra critical for aircooled engines.
  6. #25
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by MuRtAzA.KhAnZaDa View Post
    neecha dikhanay ka mera kabhi program nahi hota - mein khud nacheez hoon. Masla ye hai ke physics meray liye "fun" hai - aur engine ki dynamics uss se bhi zyada.
    - btw combustion chamber mein combustion horahee hai - dono valve open pe woh bhi CG125E mein? meray khyal se iftaar mein 2 cup chai hojaye
  7. #26
    Dec 2013
    Hyderabad
    23
    71
    Simple (Y) .
  8. #27
    Dec 2013
    Hyderabad
    23
    71
    I mean is itni si bat mai debut pata ni q shuru hojati hai.
  9. #28
    Chaudhary007's Avatar
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    Provided that the oil pump is alright and head work has been recently done
    Replacing the cam followers, cam gear and cam shaft should solve this issue.
    help me honda 125 engine is very heat up -1591732help me honda 125 engine is very heat up -1591733
    If you ride like there's no tomorrow, there won't be.
  10. #29
    Site Banned Follow
    Abdullah9014's Avatar
    Jan 2012
    Rawalpindi
    27
    129
    @Xulfiqar
    Sir can you please help me regarding a small issue i am experiencing with my CG125 2011
    I have recently got the headwork done complete overhaul. New carb and a new plug coil
    i am experiencing an issue that whenver i accelerate from constant speed there is a slight hesitation, the bike stalls for like a half a second and than it's fine.
    Similarly if i decelerate and during that deceleration if i decide to accelerate again, no matter how gently i twist the throttle there is a slight hesitation. The problem existed with my previous carb as well along with some popping. The popping sound has been resolved thanks to Air cutt valve on the new carb however this hesitation remains.
    I have also installed new intake manifold and new air filter, however the problem persists.
    There is no hesitation from standstill no matter how much i push it's smooth all the way. The problem occurs when accelerating from constant or while decelerating.
    Any help would be really appreciated ?
  11. #30
    kamoojan's Avatar
    Mar 2014
    34
    dear all ap may se koi betaye k best honda 125 mecnic in karachi may kun hai jo 125 specialist ho ar her kaam acha janta krta hoo.
    may ek ko janta hoo mrg ab wo buhad kam shop per milte hain zada waqt tableekh may lagatay hain unka naam babu ustaad hai sadar akbar road walay
  12. #31
    88azi's Avatar
    Jul 2015
    28
    44
    Same heat up issue with my honda CG125 2012 model everything seams fine from A to Z but only thing remains is heatup it freaks me out when i run like 15 kilometers..i live in lahore help me guys where can i find best mechanic for 125
    Sent from my iPad using PW Forums
  13. #32
    88azi's Avatar
    Jul 2015
    28
    44
    Quote Originally Posted by kamoojan View Post
    Visit Ranchor lane bro .. Waha pe ayk say bhar kar ayk ustad baitay hoay hai
  14. #33
    kamoojan's Avatar
    Mar 2014
    34
    rancholine bhi ja chuka hoo wahan k shops kepper ne betaya hai yahan total 70 k ap ko mechanic milay *** 125 k leya nhi ar parts ki market hai wahan her koi ttols le kr betha hai k mechanic ho beshak kam aye ya nhi sahe
  15. #34
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by 88azi View Post
    how are you determining that the engine is overheating?
  16. #35
    88azi's Avatar
    Jul 2015
    28
    44
    Thanks for reply xufiqar bro i dont know yar bought this125 few days back everything else is fine but after riding for few minutes bike get extremely hot can feel warm from engine and even if someone sits back feels that heat too thats for i made a visit honda workshop today they told me its coz of clutch plates. I ask my friend who own 2012 said he didnt have this issue but he advised me to lose tappet a little bit it will solve the issue..changed engine oil today it solved a little bit not completely. What u say about this issue you seems expert solve this mystery yar and also advised me of good mechanic in lahore only for CG125
    Peace
  17. #36
    88azi's Avatar
    Jul 2015
    28
    44
    Acha hmmm! Waterpump ke area mai . Mai ne suna hai kafi achay mechanics baitay hai waha pe ayk dafa chakkar laga.. Warna phir liyari ja lolz.. Mera ayk dost wahape rehta hai us nai bhot tarifay ki ti waha ke mechanicske agr apko jana hai to mai poch leta ho shop name and address
    Cheers
  18. #37
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Peace
    have you owned a Honda CG125 before? - the entire engine casing acts as a heatsink for the engine - meaning it will get hot, as it is a vertical mounted engine the hot air will be felt by the rider and pillion too - add to that the exhaust also shedding its heat into that same air.
    The engine is extremely simple. Anyone who works on honda cd70e can repair and tune a honda cg125e.
  19. #38
    88azi's Avatar
    Jul 2015
    28
    44
    Xulfiqar u the champ bro its first time i own cg125 its good bike but not as comfortable as 70cc china bike in rush hours like these days i dont know why cg125 feels hard to handle heavy with hard accelerator and clutch.. Maybe im not used to it .. But snyway thanks for ur reply it helped a lot
  20. #39
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    Actually you are saying quite the opposite.
    It's been one year since i switched from CD 70 to CG and have found CG better in every respect.
    3.00-17 rear tyre means more grip, mine handling is excellent and acceleration is smooth. Due to 5 clutch plates the clutch obviously feels a bit harder but proper lubrication can minimize this effect.
    Yes i agree that vibration is far more and it feels like the engine is about to burst at 100 but it is definitely more comfortable than any 70cc. Just get it's tappet adjusted from a proper mechanic via feeler gauge and get it properly lubricated. I would recommend changing the air filter and spark plug. And if you are finding it uncomfortable do check shocks for leak as well.
  21. #40
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    by your posts it seemed that you were not a previous CG125 owner.
    the CG125E clutch is harder due to powerful pressure plate springs and the accelerator was even harder on old models due to a fatter spring lifting a bigger slide in the carby, it also had a small kick which reduced the torque you applied from your foot. It also was pretty jerky and raw in the low rpm - think of it as dumping a lot of torque as you released the clutch.
    The newer models are very tame and easy, easy to start with longer kick pedal, softer and manageable controls, smoother power delivery etc. You will get used to it.
    As chaudhary007 mentions - get the engine tuned correctly, have the mechanic inspect the lower rockers and replace as necessary. They are usually overlooked in such symptoms.
