Results 1 to 9 of 9
Like Tree7Likes
  • 2 Post By crazy_rider
  • 3 Post By Chaudhary007
Thread: help regarging alteration on cd 100
    crazy_rider's Avatar
    Jun 2008
    30
    245
    Default help regarging alteration on cd 100
    i visited mc leod road at lahore to fix indicators a mechanic there advised me alter my stock piston with cd 70 piston he said that cd 100 piston is short in length and cause noise you get better performance with cd 70 piston i dont get his point how a small piston give better performance experts jump in with ur advice
    lEt thE bEast rOar!!!!!!!!!!
    awaiz43's Avatar
    Oct 2014
    Rawalpindi
    29
    238
    interested to get the answer unfortunately i dnt have the answer whats the point in smaller piston to help reduce sound.
    Chaudhary007's Avatar
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    Cool Expert
    Next time you go to him ask him "knsa sasta nasha kartay ho bhai ?"
    Now coming to the point the length of the piston has nothing to do with the noise.
    Basically a piston has two parameters bore and stroke. The picture below shows what is called a bore and what is called a stroke
    help regarging alteration on cd 100 -1607973
    The height of the piston is the same distance which the piston travels up in the cylinder.
    Now your CD 100 bore is 50mm and Stroke is 49.5mm as can be seen in the specs sheet below
    help regarging alteration on cd 100 -1607992
    Cd70 piston is out of the question it's stroke of 41.4mm would mean that the piston would never travel the required distance it is supposed to travel and with a bore of 45.6mm would mean that you would have to put it in a sleeve of diameter 4.55mm to adjust the cd70 small piston. Why would you do that ?? I am pretty sure this setup would never work in the first place due to piston height (stroke) being far too less.
    Now suppose ustad g was referring to the chonda's piston than it's a possibility. At this point i would like to say that chonda's, cd100 and CG125 piston's all have the same stroke i.e. 49.5mm.
    The difference comes in bore which is 47mm (chonda), 50mm(cd100) and 56.5mm(cg125) respectively
    Again in order to put 47mm dia (bore) piston of chonda into your 50mm wide cylinder you would have to install a 3mm sleeve.
    Why would you want to do that ? Even if you do that basically your cd100's cubic displacement of 97cc would come down to 86cc of chonda's. Why!!!!!! Why!!! plz tell me why ??
    People who own chonda's get their cylinder's bored to install bigger cd100 or suzuki sprinter's piston to increase performance and ustad g is suggesting you to do the opposite and reduce your engine displacement and hence in no uncertain terms reduce power with it.
    Are you sure he isn't on some sort of medication ??
    If you ride like there's no tomorrow, there won't be.
    slakr's Avatar
    Oct 2009
    31
    1,182
    18 Post(s)
    Ustad G bh hud kartay hain .. Perhaps he was chota ustad.Please don't do this or you will ruin your bike
    AkhlaqAhmed's Avatar
    Jul 2012
    118
    2 Post(s)
    hahaha woh macanic nai hai bhai mistri hai .....bara piston zada power de ga .......ab to 70 main aj kel her bacha 100cc se 115cc tak ka piston lane aa jata hai ....
    Jun 2008
    30
    245
    Default Bhai log yehi baat
    Thanx experts for reply yehi baat tu mjh samjh nai arai ha k log bara piston lagate hen performance k leye aur cd100 ki performance se mae satisfy hon iska comfort level bht ala ha mgar maeri behas per b wo nai mana
    Mazay ki baat us ne mjh misal jo di wo sunie
    Kehta ha k pani Waly pipe ko agar hath mae pakro tu pani Paeron pe girta ha aur agar agay ungli rakh do tu pani dour ja k girta ha yehi example wo fit kar rha tha 70 k piston k sath mean kaese 70 ka piston compression banae ga huh!
    Hahahahahahahha ha na mazay ki baat
    Kehta ha cd 70 ka cylinder laga lo ya phir sleeve laga lo piston 70 q k piston rod same ha magar mere Pallay us ki bakwas kuch nai lagi
    Jul 2012
    118
    2 Post(s)
    hahahaha sorry to say dat bro woh mistri hai mechanic nai ..
    Jul 2012
    118
    2 Post(s)
    em a professional em raning my on shop .i know very wel kon sa piston or kaya sating chaol rahi hai lahore main 70 ko 125 se age lagane main ...
    Jun 2008
    30
    245
    bhai log meri samjh mae ye nai arha ha k kam stroke wala piston cd 100 ki stroke kaese puri kaerege mean TDC or BDC ki aur ye k aisa kya jadoo wo karega k cd100 ki performance b bharha de ga aur mileage b
    meri cd100 ki performance se mae khush hn ye 2005 ka model ha tbse mere pass ha arround 200,000 km drive b kar chuka hn mileage 60 km\liter deti ha jo k maere bhai ki cd70 ne kabhi 50 km\l se uper nai de ha tu mae kaese maan lon k cd 70 ka piston laga k performance bharh jae gi aur mileage b yaar cd 70 piston cd 100 bike ka load utha hi nai sakta q k wo cd 70 ka bari mushkil se uthata ha tou wo kaese performance ki baat karta ha mjh koi problem nai ha cd 100 k piston se aur maene lagwana b nai ha lekin aik baat mjh pata chali aur mae soch mae p[arh gya hn k ye kya mazak ha cd 70 aj kal mjh pakar b nai saki ha apne engine mae tu wo mere engine khaak perform karega
    mera piston cd 100 ka laga hua ha aur 100 number chal rha ha tu wo kehta ha k sleeve lagwa k cd 70 ka piston laga deta hn ..... mean japani pagal hen k unho ne cd 100 k leye new piston lagaya.
    kehta k yahama 4 stroke mae bht kia h aye kaam aur bike owners ne bht shukriya kia k maene unki jaan chura di mean uska piston bht tang karta tha hahahahahahahahahahaha
