Results 1 to 11 of 11
Thread: CG125 Engine (Anatomy)
    Chaudhary007's Avatar
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    Cool CG125 Engine (Anatomy)
    CG125 Anatomy
    This video shows how a Pushrod single cylinder (CG 125) works with a dissected engine showing moving parts. Behind this OHV you can find an OHC single too.
    i have a question for you, there is a mistake in the setup can you point out what it is ?
    If you ride like there's no tomorrow, there won't be.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    nice,
    mistake as is in missing the oilers for the upper rockers and also the camwheel?
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    Red face
    nice,
    I think i see a cam gear beneath the cam followers but anyhow there might be other things missing as well, the mistake is in the main basic process of combustion that is taking place.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by Chaudhary007 View Post
    whats wrong with it?
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    Spark denoted by a light is taking it place at every cycle (every time the piston comes up). It supposed to happen after alternate cycle in a typical 4 stroke engine....... In exhaust stroke there is not spark.
    At the moment it's depicting a sort of 2 stroke engine in which the spark takes place in every cycle.
    The sole reason why a kawasaki gto would smoke cg every day of the week
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Lol its not a mistake cd70 cg125 cd200 all have waste spark ignition system and its Normal for spark to occur on exhaust Stroke
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by saboor73 View Post
    Lol its not a mistake cd70 cg125 cd200 all have waste spark ignition system and its Normal for spark to occur on exhaust Stoke
    as mentioned by saboor
    honda CG125E has wasted spark ignition - the plug will fire everytime the cylinder reaches TDC no matter if on the compression stroke or exhaust stroke.
    infact - any single cylinder motorcycle with its pulser, points on the crank or magneto will be wasted spark - even CD200 twin is like that - it wastes a spark on each cylinder.
    Honda CB125, CB185 etc engines are not wasted spark - their triggers are fired from the cam.
    btw - two stroke are not just only fires on every stroke, - in a 2 stroke every upstroke is compression and it results in a power stroke.
    the exhaust happens as it descends and opens the exhaust port, at the same time the transfer ports open to transfer new mixture from the crankcase to the cylinder.
    everytime the piston rises a negative suction is created in the crankcase of a 2 stroke and the intake stroke takes place.
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    like old c90
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    [/b] like old c90
    yes - that too had it from the cam.
    it runs half crank speed - so it can fire every power stroke.
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    @Xulfiqar
    My bad....i didn't knew
    Can you please tell me about the large vacuum which is created in the intake manifold and carb upon release of throttle ?
    And how a bit open exhaust can result in popping during decel ? Can a small difference in dia from the stock muffler can cause this condition ?
    asjdsm's Avatar
    Apr 2009
    30
    3,476
    57 Post(s)
    3 Thread(s)
    @Xulfiqar
    Yes it can.
    At bit he exhaust and inlet(to match inlet manifold with inlet port after I swapped a pz carburettor on chonda 70 head ) .
    I had experienced it. They cause turbulence at unwanted place and at unwanted time.
    All ports should be aerodynamically in flush contact for best smooth ride.
    Sent from my Nexus 5 using Tapatalk
