Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Like Tree22Likes
Thread: Problem with new CG125
    asimzb's Avatar
    Jan 2016
    71
    Default Problem with new CG125
    Hello,
    My bike is leaning towards right side when hands are off. I did not realize it before few days ago when just for fun i took my both hands off for a few seconds and my bike was leaning to right side. This seems like bike is heavy on one side but if i ride it normally i don't even notice anything unbalance.
    I checked and corrected the rear wheel alignment but that didn't solve the issue.
    What could be the causes other than that ??
    sent from Motorola device
    Alir1's Avatar
    Aug 2013
    232
    2 Post(s)
    I think your bike is victim of this Name:  ImageUploadedByPW Forums1452935331.380386.jpg
Size:  153.0 KBName:  ImageUploadedByPW Forums1452935354.406973.jpg
    Chaudhary007's Avatar
    Dec 2009
    Rawalpindi
    26
    607
    16 Post(s)
    4 Thread(s)
    Quote Originally Posted by asimzb View Post
    Hello,
    Leaning towards right side ??? Has anybody also rode it to confirm ??
    let someone else ride it and you ride on another bike at the back and see if the tires of your bikes are aligned or not.....if they are misaligned than your frame is bent....due to an excessive force applied from either the back or front.....usually frame misalignment happens after sever accidents......but in your case since the bike in new u should claim warranty and to be honest there in no real solution tell them to give u a new one......cuz other wise in order to straighten frame they would have to remove everything up till the chassis and than hathora ustad will do an unsatisfactory job and the issue would remain there.
    If you ride like there's no tomorrow, there won't be.
    asimzb's Avatar
    Jan 2016
    71
    Im not sure if they would give me another bike. Also they would say bike is perfectly OK bcoz the issue is when u lift ur hands off the handle, and i think they wont consider it as a fault.
    I will try to ride someone else bike to make sure is it only my bike or every bike
    7thgear's Avatar
    Aug 2007
    34
    3,918
    79 Post(s)
    13 Thread(s)
    I think this is the reason..
    Quote Originally Posted by Alir1 View Post
    Web: http://www.bikepics.com/members/sniperr and http://wanderersbook.blogspot.com
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    how is the bike handle free play check the handle movement by putting bike in center stand
    how is the alignment of handle
    asimzb's Avatar
    Jan 2016
    71
    Handle free play is fine and OK nothing unusual
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    i will say don't worry, frame are strong and alignment in atlas honda bikes
    is very good no issue in chinese bikes you would see rear wheel not aligned
    with front wheel
    asimzb's Avatar
    Jan 2016
    71
    Yes, the bike is perfectly fine and i dont notice any alignment or balancing issues. It was until i just lift my hands off the handle for a check and bike was forcing itself to the right side. I don't understand what could cause this strange behaviour.
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    i am also very decent rider but i have myself also tried this thing
    leaving hands just little bit to check not for alignment bus aise hai
    it did not move anywhere used to go very straight
    asimzb's Avatar
    Jan 2016
    71
    U r right.. The bike should go straight.. There could be something wrong with my bike, which im trying to find out
  12. #12
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    different bikes behave different i think you should try some other friend's cg125
    this will remove your confusion
  13. #13
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    and to me it looks like just issue of adjustment of handle free play
    may be in your case your cg's handle is too much free so if you get
    it little bit adjusted i think issue will solved mechanic adjust handle
    free play with flat handle screw driver and hammer there is adjuster
    in handle for free play adjustment
  14. #14
    asimzb's Avatar
    Jan 2016
    71
    Ok i will try to ride another cg.
  15. #15
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Check if both front shocks have same stiffness
  16. #16
    asimzb's Avatar
    Jan 2016
    71
    Quote Originally Posted by saboor73 View Post
    R u sure this can be the issue?
  17. #17
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Its quite possible if your left shock is less stif it will make bike lean on right side
  18. #18
    asimzb's Avatar
    Jan 2016
    71
    But how can i check a single shock stiffness while both are fixed to body.
  19. #19
    hassan_123's Avatar
    Nov 2006
    22
    35
    3 Post(s)
    Bro did you try doing it on a different road?? i also own a new model Cg but did not face any such issue..this might be a case of an unbalanced road..
  20. #20
    hassan_123's Avatar
    Nov 2006
    22
    35
    3 Post(s)
    1.Check tyre pressure and fill it according to the recommended air pressure in bike's manual..
    2.Take your bike to any "rim through wala" and get your front rim checked..
    3.Get your tyre checked from a tyre shop not a petrol pump puncture shop..
    4.Get your handle Checked..
    5.Check the issue 3,4 times on different roads..
    I've experienced this for a long time on my suzuki gs 150.. after 2 years, came to know that the front tyre was out (misaligned)
    .. changed it and the issue was solved after that..
    If it doesn't get solved after all this, then Find a CG rider and give him your bike to test it out.. if he says its fine then probably it's only in your mind..
