Results 1 to 8 of 8
Like Tree3Likes
  • 1 Post By amjad635
  • 2 Post By amjad635
Thread: deluxe 2015 visor issue
    fazeil.chaudhary's Avatar
    Jan 2016
    Bahawalpur
    20
    233
    3 Post(s)
    Default deluxe 2015 visor issue
    hy guys
    i have cg 125 deluxe 2015
    my visor is making noise any solution??
    i got my visor cracked then i replace it and get new visor
    the new visor is making noise
    f4fraz's Avatar
    Dec 2013
    34
    651
    17 Post(s)
    Quote Originally Posted by fazeil.chaudhary View Post
    hy guys
    I suggest to screw off the visor and use some rubber washer with screws.
    OR
    use glue/magic at the areas where u feel are lose. do it properly on all joint areas.
    Hope these will work
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    deluxe 2015 visor issue - 1603586d1439036995 honda cg125 dream 20150808 141923
    first of all check bolts if they are tight and also check nothing is touching visor
    like dashboard that fitted with visor if every thing is fine this is major reason
    of noise mounting clips that hold headlight with visor once they are removed
    they become loose so use some paper or make them tight by using some force
    and again install so that they fix and lock tight
    f4fraz's Avatar
    Dec 2013
    34
    651
    17 Post(s)
    Quote Originally Posted by amjad635 View Post
    bas ziada force na laga dena phir kaho gy is se acha to pehly tha...
    clips wagera ke mamly mei mera experience bad hi raha hay
    jab bhi hath lagata hon break ho jaty hain. is liy me ab hud nye cherta.
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    f4fraz
    g han khayal rakhna chahiye en clips ka aur buhat zyaada force use na karna
    ke clip h toot jaaye waise yeh hai metal ki clip plastic nahein
    Jan 2016
    Bahawalpur
    20
    233
    3 Post(s)
    exactly brother
    but i find these headlights clips from every honda dealer shops and local spare parts shop they are not available thats my problem
    where can i find these clips??
    amjad635's Avatar
    Sep 2011
    Select City
    5,713
    13
    228 Post(s)
    10 Thread(s)
    unfortunately they are no where available mine cg dream visor broken so i
    replaced it but then faced issue with these clips but then i used firm paper to
    get rid of this issue bro i suggest remove these clips fold them or press them
    so that they are tight and than insert in tabs so that they lock firmly if you
    are failed to do than use paper as i had done
    I request you to register a complain for unavailability of these clips show
    your frustration & trouble you are facing these clips. I had registered my
    complain more we complain chances are these clips will be available at
    atlas parts dealers than will be safe from this trouble
    Customer Care number = 0800 24522
    deluxe 2015 visor issue -1659990
    coldharwest's Avatar
    Feb 2006
    Dera ghazi khan
    34
    77
    When will deluxe 2016 model launching? ?
