Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Like Tree11Likes
Thread: CG 125 1997 model engine again showing problems
    fazi54's Avatar
    Jun 2015
    19
    Angry CG 125 1997 model engine again showing problems
    Hello to All I'm new to this..
    Guys i bought 1997 CG 125 because my friend had one same model and i liked it alot.. so i bought one same model
    it had some issues in it connector rod was supposed to be replaced..
    so i replaced every thing by putting genuine Honda parts..
    CAM, Rod, Tappet plate, bearings, rocker arms etc was changed..
    after a month engine started noise i got it checked mechanic said CAM will be replaced..
    then after even replacing noise started after 2 days..then he said tappet plate is causing the noise..
    after even replacing the tappet plate 2nd time in 2 months.. it even sounded off..
    now they say that again connector rod and CAM will be replaced..
    any suggestions am tired off these ustaads mechanic
    By even replacing all of these items twice.. also genuine Honda parts were used..
    and in 2 months they all are in same state they were before.. Kindly help me..
  2. 25-02-2016, 04:14 PM
    PakWheeler
    Reason
    Duplicate
  3. #2
    Navqam's Avatar
    Feb 2009
    Rawalpindi
    304
    2 Post(s)
    7
    Sad to know. Very un-fortunate. Fact is that its very hard to find right (original) parts and the fellow who install these in your bike. Sometimes original parts are being ruined by 'So Called Ustaads' and it is asked to the customer to replace again & again...isn't it sad, waste of hard earned money and precious time...all resulting in ruining your dear BIKE...
  4. #3
    fazi54's Avatar
    Jun 2015
    19
    what to do off these Ustaads.. tried different ustaads but didn't work out..
  5. #4
    metalhead's Avatar
    Oct 2006
    Wah cantt
    1,307
    49 Post(s)
    Part replacement is not always the solution.
    For example, you replace worn out parts but neglect the lubrication. You will end up wearing out same parts again and again.
  6. #5
    patrolvtc's Avatar
    Feb 2011
    193
    3 Post(s)
    borther sincere suggestion to you is that sale it out.... i also own cg right now and ybr125 .... once cg starts showing weakness you cant get it stable again especially the cam problem one is suppose to get it replaced every 2 3 months ... so buy a brand new cg if youare cg fan or else there is no use to buy second hand cg..... try some other bikes like GS150 or YBR125.... they good in almost every aspect as compare to cg
  7. #6
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by patrolvtc View Post
    The weak point of this engine Is that its cam gear need to be placed dead straight a lil play in cam can deshape it
  8. #7
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by sarfraz54 View Post
    was the oil pump ever checked for wear? - were new O rings used on its install? Its vital they be installed without any sealant too.
    Did your mechanic ever check the lower rocker to pin clearance?
  9. #8
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    My bike cam gear have started to show sign of being worn from last six months any tips to ensure that while replace can gear it sits dead straight
  10. #9
    patrolvtc's Avatar
    Feb 2011
    193
    3 Post(s)
    Quote Originally Posted by saboor73 View Post
    Sale it bhai ... Jaan **** jai gee koi or bike buy ker lain
  11. #10
    fazi54's Avatar
    Jun 2015
    19
    yes they were checked also used new O rings at every replacement..
  12. #11
    fazi54's Avatar
    Jun 2015
    19
    brother my friends cg was rebuild it had more Parts worn out than mine but even after 1.5 years of usage its engine is as silent as a new bike complete sound less engine thats the reason i bought a down model at first place..
  13. #12
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    you need a bore guage to check that, If its worn oval then you need a master machinist who has the alignment jig for this engine. Its not a simple tighten in chuck and rotate on spindle solution.
  14. #13
    fazi54's Avatar
    Jun 2015
    19
    & where to find this Legendary mechanic
    because we need him.. Tired of Ustaaadz.. :/
  15. #14
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    bore gauge is a tool I expect any respectable mechanic or technician to own, one can even make a setup with dial gauge - I know the street mechanics wont even know what this is.
    About the master machinists - There were two that made the jig from a new engine casing - both behind the Radio Pakistan market. Gohar machine works or something like that, very small shop.
    Worst comes to worst - you can buy a new engine casing from Atlas Honda, it takes about 2 weeks time and they give you a new casing with your engine number stamped on it. - Its not cheap.
    was your rebuild done with measurements or was everything "haath ka andaaza"
  16. #15
    fazi54's Avatar
    Jun 2015
    19
    yes haath ka andaaza.. other day i asked him about feeler guage for tappet setting.. he said bahot use kiyaa bakwaas hai andaaza theek rehta hai..
    also the address bro where is it Lahore Karachi Pindi?
  17. #16
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    your mechanic is chalta phirta
    useless IMO. - find a better one.
    the address I posted above was for Karachi only.
  18. #17
    fazi54's Avatar
    Jun 2015
    19
    i am from kpk and this is the 4th mechanic i've consulted.. all are "ustaaaadz"
  19. #18
    wheelman84's Avatar
    May 2010
    31
    82
    8 Post(s)
    As pointed out by Sir Xulfiqar, Oil pumps in CG 125 engines are often not properly checked by the mechanics. Replace the oil pump. Check valve guides for any free play and if the ring where valve sits has caved in. Find a good machine shop and get valve guides replaced if needed.
    New cam gears by Atlas are pretty useless. I have seen new cam gears making noises. If you need to change your cam again, use CRLF cam gear. CRLF wont last more than 10-12 months but cam gear noise will vanish for a few months.
    Next time you visit the mechanic, ask him to remove the tappet assembly and get the push rods out. Check push rods for wear and scratches.
  20. #19
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Thanks for help sir
  21. #20
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Ahl have changed push rod design of cg125 and started installing thinner pushrods which I think will get bend soon does bend push rod damage cam gear
    CG 125 1997 model engine again showing problems - YoyqNMk
Tags for this Thread
