Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 78
Thread: Vibration in CD70
    naqqash10's Avatar
    Nov 2015
    Faisalabad
    20
    70
    Default Vibration in CD70
    Need seniors Advice
    My cd 70 giving to much vibration
    And
    Engine sound is changed alot
    Odo is 18000+
    So which engine oil did u recommend??
  2. #21
    naqqash10's Avatar
    Nov 2015
    Faisalabad
    20
    70
    Quote Originally Posted by Hassan1991 View Post
    While driving press and release clutch in every gear if you feel like clutch plates slips or bike doesn't respond then they are weak......if they are slightly weak then clutch slips in 3 or 4 th gear.
    Bike does not respond??
  3. #22
    naqqash10's Avatar
    Nov 2015
    Faisalabad
    20
    70
    Quote Originally Posted by saboor73 View Post
    Get all bolts tigtenig
    use charade oil pump chain as timing chain
    Place a washer on the place where exhaust is attached to control arm with bolt
    Use zic m5
    Name:  ImageUploadedByPW Forums1464945883.631165.jpg
    Saboor bhai
    This one?
  4. #23
    hassantahir2's Avatar
    Mar 2016
    Faisalabad
    22
    813
    17 Post(s)
    Quote Originally Posted by naqqash10 View Post
    If bike is in 3rd or 4th gear then press the clutch rev the bike hard and release the clutch with jerk if the bike picks upp the speed rapidly then your clutch plates are ok.. If there is a little delay in response the clutch slips the pick would be affected.....
    Don't know i have explained correctly or not i am a bit bad at explaining.. 😛
    Sent from my D2502 using PW Forums mobile app
    Four wheels move the body
    Two wheels move the soul
  5. #24
    naqqash10's Avatar
    Nov 2015
    Faisalabad
    20
    70
    Quote Originally Posted by hassantahir2 View Post
    Got it
    And how to order zic oil onilne?
  6. #25
    Mar 2016
    Faisalabad
    22
    813
    17 Post(s)
    Got it
    You have to make a account on zic website and then go to the product which you want to buy select that product which you want to purchase also select quantity. And DONE...
  7. #26
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Saboor bhai
    This one?
    Yes yehi wala
  8. #27
    Hassan1991's Avatar
    Mar 2013
    20
    2,275
    37 Post(s)
    Right
    The first step towards knowledge is to know that WE are IGNORANT
  9. #28
    naqqash10's Avatar
    Nov 2015
    Faisalabad
    20
    70
    Yes yehi wala
    Name:  ImageUploadedByPW Forums1464950107.897564.jpg
  10. #29
    naqqash10's Avatar
    Nov 2015
    Faisalabad
    20
    70
    Yes yehi wala
    Saboor
    Tell me the difference between 4ply tyre and 6 ply tyre??
  11. #30
    Hassan1991's Avatar
    Mar 2013
    20
    2,275
    37 Post(s)
    problem solved or still can't sign up?
  12. #31
    Mar 2016
    Faisalabad
    22
    813
    17 Post(s)
    Saboor
    6 ply tyres are thicker than 4 ply tyres. Hence they have a little longer life. Are less prone to punctures.
    Very little increase in engine load but that is negligible.
    I would choose 6 ply tyre's over 4 ply one's any day.!
  13. #32
    naqqash10's Avatar
    Nov 2015
    Faisalabad
    20
    70
    No sign up
  14. #33
    naqqash10's Avatar
    Nov 2015
    Faisalabad
    20
    70
    I m using 6 ply tyre
    No punctures
    Once tube was failed...
    Get a new one as a clam..
  15. #34
    Hassan1991's Avatar
    Mar 2013
    20
    2,275
    37 Post(s)
    No sign up
    just sign up.....don't faced any problem
  16. #35
    naqqash10's Avatar
    Nov 2015
    Faisalabad
    20
    70
    Tried
  17. #36
    Hassan1991's Avatar
    Mar 2013
    20
    2,275
    37 Post(s)
    Tried
    then try try again
  18. #37
    naqqash10's Avatar
    Nov 2015
    Faisalabad
    20
    70
    then try try again
    Ok brother
  19. #38
    naqqash10's Avatar
    Nov 2015
    Faisalabad
    20
    70
    then try try again
    Name:  ImageUploadedByPW Forums1465052008.750610.jpg
    Got it
  20. #39
    Hassan1991's Avatar
    Mar 2013
    20
    2,275
    37 Post(s)
    Got it
    Congrats brother also Share your experience
  21. #40
    naqqash10's Avatar
    Nov 2015
    Faisalabad
    20
    70
    Bhai mobile pa zic ki website sahi tarhan open e nai hoti
    Laptop sa ap zic ki side pa jao wahan pa sign up ka option ha wahan sa easily account ban jata ha!!
    Ab delivery pta nai kab tak ho gi
