Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Like Tree9Likes
Thread: Honda CG125, speed problem
    sharmila_jin's Avatar
    Sep 2008
    Chakwal
    25
    17
    Unhappy Honda CG125, speed problem
    Hello Dosto, i got 2014 CG125, regularly tuning and oil change after every 1000 km. Most of time Honda delaers se he karwata but from last 3 -4 months se bht problem kar raha, increased vibration, 97Km/h se uper nae jata jitna marzi accelaerate karlo, as I already made 122 Km/h using online speed application. ajeeb o ghareeb type ki awazain deta. Kuch samhaj nae araha. what do u suggest ?
    aaqil30's Avatar
    Dec 2013
    Rawalpindi
    20
    242
    2 Post(s)
    Quote Originally Posted by sharmila_jin View Post
    Kitna chla hai? Carb khulwaya? Oil kon sa dala?
    Sent from my SM-G800H using PW Forums mobile app
    Sep 2008
    Chakwal
    25
    17
    2 years and 6 month hogae jis mai se pehla sal to bht he chala hai month mai 1100 1200 Km chal jata tha phir aik sal bht kam lekin poray sal mai 500 600 Km chala hoga last 4 month se bhe 1100 1200 per month, wese Honda ka oil he use karta tha but is dafa aik imported oil use kia hai 20-50, engine heat to bilkul nae hota but speed wala problem still same or vibration ki waja se 70 Km/h se uper le k janay ka dil he nae karta. its so annoying. grrrrrrrrr, trrrrrrrrr sounds carb nae khula abhe, race wire change karwai thi 1 sal pehle
    aaqil30's Avatar
    Dec 2013
    Rawalpindi
    20
    242
    2 Post(s)
    Use atlas oil. Clean the air filter. The spark plug. And oil the chain. Than drive it full throttle with great care for 5-6 min. After the oil comletes 200kms.
    hassantahir2's Avatar
    Mar 2016
    Faisalabad
    22
    812
    17 Post(s)
    Quote Originally Posted by aaqil30 View Post
    Can i ask you why you are recommending AHL oil...
    Its not a good oil instead of this i would have recommended ZIC 20w40, Valvoline 20w50, Liquimoly 20w50. ZIC and Valvoline almost cost equal to AHL oil and are better than that.
    For oiling the drive chain SGO SAE90 Gear oil is best if chain lubricant is not available.
    Sent from my D2502 using PW Forums mobile app
    Four wheels move the body
    Two wheels move the soul
    Mar 2016
    Faisalabad
    22
    812
    17 Post(s)
    So it means approximately your bike has covered some 19000-20000km.
    Well Honda CG 125 usually vibrates but if the vibrations have increased than before then check and tighten all the nut bolts of the bike.
    Adjust drive chain tension and oil that.
    Do get the spokes of wheels tightened.
    Clean the air filter properly.
    If plug is not changed till now then change the plug.
    Adjust the valve(tappet) clearance.
    Adjust Air fuel mixture.
    Use some quality engine oil. But that must be wet clutch safe and api grading no more than sj.
    If the problem remains unsolved then check the Push Rod's, Rocker Plate, Cam Followers, Cam Gear.!
    umar1994's Avatar
    Aug 2015
    21
    117
    same problem with my cg but its completely new
    Sent from my SM-N900 using PW Forums mobile app
    aaqil30's Avatar
    Dec 2013
    Rawalpindi
    20
    242
    2 Post(s)
    Quote Originally Posted by hassantahir2 View Post
    These bikes don't deserve that oil. The makers of this bike know what bakwas type parts they have put in it and they make the oil accordingly for it. This is no heavy bike no extra ordinary air cooled engine. It's a simple decades old 125. There's nothing in it that ahl oil won't do justice to. Other oils are not made for this. Some slow the bike down due to their viscosity some leak the seals. And im talking about long term. A new bike will tolerate any oil. But as it gets older thick oil will be a problem and will create for drag. Ahl oil is best in every terms ONLY FOR HONDA BIKES!!!!!!! And change at 1000kms. No need to push your luck!!!
    Hassan1991's Avatar
    Mar 2013
    20
    2,259
    37 Post(s)
    Tight the bolts of handle,front shock covers,headlight supporters,mud guards,back lights...... usually these things make's annoying noises
    The first step towards knowledge is to know that WE are IGNORANT
    Sep 2008
    Chakwal
    25
    17
    hmmm i will consider you suggestion as i am going for bike tour. Liquimoly bhe try kar leta hu. and what to do with light. HID lagwai jae ya sath fron shock pe aik seprate lagwai jae?
    umarjutt's Avatar
    Jun 2016
    152
    3 Post(s)
    I also baught new cg 125 38km driven filhal me 40 50 se uper ni gya hn ...... 200 per liquimolly oil dal lena ha me ny ....
    Sent from my SM-A500H using PW Forums mobile app
  12. #12
    Sep 2008
    Chakwal
    25
    17
    300 KM k bad oil change karna, 300 tak single pe running karo or running pe 50 KM/h se ziada nae jana 50 pe rakh k 7 8 kilometer janay do 300 k bad oil change karwa k aik din ragra lagao or speed check karo 2nd oil 700 se pe karwana, 3rd 1000 pe r sath tuning bhe
  13. #13
    arham.16's Avatar
    May 2015
    16
    AHL oil is not to GOod As Zic and Havoline ... Ahl oil bohat jaldi ganda ho jatta ha ma 2014 model Cd 70
    use kar raha hoon shuru sa havoline dalwaiya or 900 pa tunning or Araam sa 2-3 dawa 90-95km/h taaak
    chalaiya..Ma koi racing nah karta baas wassa hi check kya ha
  14. #14
    Sep 2008
    Chakwal
    25
    17
    Honda CG125 speed problem -1695308
  15. #15
    Sep 2008
    Chakwal
    25
    17
    Honda CG125 speed problem -1695309
  16. #16
    Sep 2008
    Chakwal
    25
    17
    Honda CG125 speed problem -1695310
  17. #17
    Sep 2008
    Chakwal
    25
    17
    Hello Friends Problem Solved.... the main cause of vibration was engine. One support axle was broken and for upper support axle of engine, thanks to superb quality of Honda both holes are broken from frame due to very low class quality of metal. I am uploading Images. I took six hours and 1500 Rs for all mechanical and welding work. but now there is no vibration. it is giving a very smooth ride. tuning and engine oil also done, drive chain setting. i tested it on Islamabad Highway and 110 Km/h is easily achieved.
  18. #18
    Hassan1991's Avatar
    Mar 2013
    20
    2,259
    37 Post(s)
    Extremely poor quality.
  19. #19
    umar1994's Avatar
    Aug 2015
    21
    117
    pathatic :/
  20. #20
    Alir1's Avatar
    Aug 2013
    229
    2 Post(s)
    share some pics after welding job
    Sent from my GT-I9300 using PW Forums mobile app
Tags for this Thread
