Seriously if you want to buy this machine it just have a few problem's if those problems don't bother you you can go for it...
1: Engine vibrations..
Remedy vibrations can be lessened by using the latest rocker plate design and cam gear and old Japanese thick push rod's. But you wouldn't be able to take them to zero..
2: Rear shock absorbers..
Remedy you can find Ravi Piaggio rear shock absorbers and install them they can be installed without modifications.
3: Seat foam is Hard..
Remedy you can get your seat worked upon from the poshish walay aka seat maker's.
4: Front shock absorbers are not upto mark..
Remedy you can get them filled with ATF fluid you will feel considerably better comfort.
Rest you will enjoy its acceleration in traffic twist the throttle and.........
Sent from my D2502 using PW Forums mobile app
