Results 1 to 3 of 3
Thread: Old cg 125, gear ratio changes, what to do?
    tahx's Avatar
    Jan 2016
    Default Old cg 125, gear ratio changes, what to do?
    Hello people. i own a cg 125 2005.
    i had recently changed the clutch plates and straight out of the garage, is seemed to run fine.
    the problem started from next day, i noticed the gear ratio has changed. for example for 2nd gear, i used to get the end of gear RRRRRRRR sound on like 30/35 kph, now it starts revving on around 20 kph. so while on the first day , i could get like 50-55 kph on 4th gear, now im getting around 40.
    is it the clutch plate or something else. please help me out guys! TIA
    Hassan1991's Avatar
    Mar 2013
    20
    2,265
    37 Post(s)
    ASSALAM-O-ALAIKUM
    What's the condition of your bike's engine and carb?
    Clutch plates can't cause this problem until they are worn-out.
    The first step towards knowledge is to know that WE are IGNORANT
    tahx's Avatar
    Jan 2016
    walaikum assalam.
    the bike engine is in avarage condition, so is the carb. recently i overhauled the carb myself following the manual. it seems to work better than before now.
    There is no chance of clutch plates worning out, i changed them 2 days ago.
