Results 1 to 3 of 3
Thread: CG 125 speed problem
    tahx's Avatar
    Jan 2016
    Default CG 125 speed problem
    hello. i have a 1992 cg 125 pakistan. the bike was total overhauled when i bought it. it has crossed 5000km from then. in between, changed the clutch plates and whole sprocket set.
    but the problem is, the bike hardly can cross 40-45 normally on 4th gear without any excessive noise. if i reach 65-70, the bike gives a lot of vibration. what is the possible problem here? thanks in advance.
    umar1994's Avatar
    Aug 2015
    21
    118
    maybe tappets are set tight when u tuned up last time? or might be the average is set to low
    Sent from my SM-N900 using PW Forums mobile app
    tahx's Avatar
    Jan 2016
    the top speed problem isnt from now a days, its been almost since i bought it. i see other people posting getting 60-70 in 4th gear without ease, so i thought there might be a problem im not getting. can it be the carb?
