Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Yamaha R-125 vs Aprillia RS125 vs Honda CBR125
    abdulsattar_civic95's Avatar
    Jan 2007
    27
    790
    Default Yamaha R-125 vs Aprillia RS125 vs Honda CBR125
    Guys rate these two bikes in style,technology,power,performence.
    Yamaha YZF-R125
    Yamaha R-125  vs  Aprillia RS125 vs Honda CBR125 -578932
    YZF-R125
    Features -
    125cc SuperSport Motorcycle
    High-revving liquid-cooled 4-stroke single
    R-series styling
    Aluminium swinging arm
    Midship muffler
    Engine -
    Engine type Liquid-cooled, 4-stroke, single cylinder, 4-valve, SOHC
    Displacement 124.66 cc
    Bore x stroke 52.0 x 58.6 mm
    Compression ratio 11.2 : 1
    Maximum power 11.0 kW (15 PS) @ 9,000 rpm
    Maximum torque 12.24 Nm (1.25 kg-m) @ 8,000 rpm
    Lubrication system Wet sump
    Fuel System Fuel injection
    Clutch type Wet, multiple-disc coil spring
    Ignition system TCI
    Starter system Electric
    Transmission system Constant mesh, 6-speed
    Final transmission Chain
    Fuel tank capacity 13.8 L
    Oil tank capacity 1.15 L
    Chassis -
    Chassis: Steel Deltabox
    Front suspension system Telescopic forks
    Front travel 130 mm
    Rear suspension system Swingarm (monocross)
    Rear travel 125 mm
    Caster angle 24.2°
    Trail 86.1 mm
    Front brake Single disc, Ø 292 mm
    Rear brake Single disc, Ø 230 mm
    Front tyre 100/80-17 M/C
    Rear tyre 130/70-17 M/C
    Dimensions -
    Length 2,015 mm
    Width 660 mm
    Height 970 mm
    Seat height 818 mm
    Wheel base 1,355 mm
    Minimum ground clearance 155 mm
    Wet weight 138 kg
    Top speed 130 Kmph
    Aprillia RS125
    Yamaha R-125  vs  Aprillia RS125 vs Honda CBR125 -578933
    RS 125Technical sheet
    Engine: Liquid cooled, single cylinder two stroke. Aluminium cylinder with Nikasil coated liner. Read valve intake. Separate lubrication. Homologated to Euro 3 standards.
    Fuel: Dell’Orto VHST 28
    Bore x Stroke: 54 x 54,5 mm
    Total displacement: 124,8 cc
    Compression ratio: 12,5 ± 0,5:1
    Fuel system: Dell’Orto VHST 28.
    Ignition: Electronic CDI ignition.
    Starting: Electric
    Generator: 12V - 180 W
    Lubrification: Separate mixing with variable displacement, volumetric pump.
    Gear box: 6 speed. 1st 10/30 (0.33) 2nd 14/29 (0.48) 3rd 17/27 (0.63) 4th 19/25 (0.76) 5th 21/24 (0.87) 6th 22/23 (0.67)
    Clutch: Multi-plate in oil bath.
    Primary drive: Gearbox: 63/19 (3.31).
    Final drive: Chain: 17/40 (2.35).
    Frame: Sloping twin-spar frame in thin wall box section cast aluminium, with reinforcement cross-ribbing.
    Front suspension: Upside down hydraulic fork, Ø 40 mm. Wheel travel 120 mm.
    Rear suspension: Swingarm with asymmetric members in thin wall box section cast aluminium. Hydraulic monoshock with adjustable spring preload. Wheel travel 120 mm.
    Brakes: Front: Floating Ø 320 mm disc. Radial caliper with four differential diameter pistons, Ø 32 mm – Ø 27 mm. Rear: Single Ø 220 mm disc. Caliper with two Ø 30 mm pistons.
    Wheels: Aluminium alloy. Front 3.00 x 17”; rear 4,00 x 17”.
    Tyres: Tubeless radial. Front 110/70 17”; rear 150/60 17”.
    Dimensions: Overall length 1955 mm Overall width (at handlebars) 720 mm Overall height (at windshield) 1100 mm Seat height 805 mm Wheelbase 1345 mm
    Fuel tank capacity: 14 litres (3.5 litre reserve).
    Carburettor: The 21 kW RS 125 (sold on the German market) is still equipped with a Dell’Orto PHBH 28 carburettor and is homologated to Euro 2 standard.
    Top speed: 180 KMPH in ideal condition
    This is the link where you can find the accleration of RS125
    http://www.youtube.com/watch?v=hxDM_CeazL4&feature=related
    sTiLl No OnE cAn BeAt HoNdA
    Jan 2007
    27
    790
    i like RS125 in power performance but in style i like R125 but overall i like RS125
    Site Banned Follow
    cyber_satan's Avatar
    Mar 2007
    86
    383
    i had an aprilla 250
    and it was FFASTTTTTTTTTT!
    RX115's Avatar
    Jan 2009
    44
    4,163
    5
    120 Post(s)
    2 Thread(s)
    @civic95 dear u mentioned above about honda cbr125 but its not in it anyway....
    i think these two bikes r equviped by difrrent technologies so its hard to rate in power and performance rather style.......
    i rate 1st aprillia rs125 due to its power and performance and the yamaha r-1 looks stylish but u will have to keep in ur mind the r-1 is latest model
    ***SPEED+ACCURACY+AGGRESSION=YAMAHA RX115***
    malikg115's Avatar
    Apr 2005
    Other
    6,536
    5
    19 Post(s)
    4 Thread(s)
    abd sattar is facing english prob
    lolz
    For Riding Jackets & Gloves, Armors, Saddle Bags, Knee & Elbow Guards etc: https://www.facebook.com/PbcMotorSport?fref=ts
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    dude...the aprilia RS125 IS the better of the three...u should see the prototype of the bike which runs in the MOTOGP...it gives those KTM one hell of a fite..the yamaha is good too...but the aprilia nukes them both (Y)
    >>Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
    Jan 2007
    27
    790
    @all
    guys cantt find the specs of CBR125 so kindly if anyone have the specification of Honda cbr125 kindly post it.
    @foosa
    yep bro we know aprillia is better in performance because of 2 stroke engine but how about cbr and r-125 which one this better both in style and performance
    mamehmood's Avatar
    Sep 2008
    702
    Aprillia RS 125 is world champion bike of 2007
    Yamaha R-125  vs  Aprillia RS125 vs Honda CBR125 -930621
    muhammadasifmehmood@yahoo.com
    Cell#: 0300-4007480
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    @sattar_civic
    bro if you ask me...the YZF-R125 of yamaha beats the cbr in everything...specs and styling...im uploading a pic of the cbr 125...have a look for urself
    Yamaha R-125  vs  Aprillia RS125 vs Honda CBR125 -930684
    mamehmood's Avatar
    Sep 2008
    702
    aprillia RS125 the fastest bike in its class
    Yamaha R-125  vs  Aprillia RS125 vs Honda CBR125 -930704
    Yamaha R-125  vs  Aprillia RS125 vs Honda CBR125 -930705
    Cell#: 0300-4007480
    Jan 2007
    27
    790
    @foosa
    thanks bro i also like r-125 and everyone know r-125 is far better than cbr 125 i think so cbr 125 is same like CBF stunner which is curruntly sale in india but if you say which bike is the fav bike in the 125cc everyone know apprillia
    @mamehmood
    yes bro you are rite
    @all
    anyone at pw have experience with RS125.
  12. #12
    La010's Avatar
    Apr 2007
    Sydney
    26
    1,792
    is any one of the above available in pakistani market?
    Buttwieser
  13. #13
    foosa's Avatar
    Oct 2006
    Multan
    29
    3,124
    5 Post(s)
    none of these bikes are available in pakistan...however u can import them anytime ...i have seen a cbr 125 or 150 in lahore...but didnt have a chance to ride on...however there was a time when i was seriously thinking of getting a rs125...but the math in the end concluded that it was too much to pay for a 125 ...but its a fast 125
  14. #14
    mamehmood's Avatar
    Sep 2008
    702
    we have tried to import aprillia RS125 from italy but it will cost RS 700,000:|
    Cell#: 0300-4007480
  15. #15
    Jan 2007
    27
    790
    @mamehmood
    really bro as per my calculations it will around 400k but how 700k its too much yaar
  16. #16
    mamehmood's Avatar
    Sep 2008
    702
    @abdulsattar
    dear abdul sattar couple of weeks ago Pakistan Tobeco Company our regular client required some sports model in 50 qty
    so we putt the matter to Piaggio and required Aprillia RS125 from Italy but at the end price was calculated till customer end RS 650,000 + its a fact so they drop the order due to price
    we ask them why its price is too high they replied that its CHAMPION bike on the track
    Cell#: 0300-4007480
  17. #17
    Jan 2007
    27
    790
    @mamehmood
    bro can u give me the specs and price of RS 50 thanks
  18. #18
    mamehmood's Avatar
    Sep 2008
    702
    50 qty means (50 quantity) not 50 cc
    @abdulsattar
    RS 50cc can be import but not single unit if u have an order of 50 units then we can arrange:p
    Cell#: 0300-4007480
  19. #19
    chanda's Avatar
    Sep 2006
    Rahimyar khan
    26
    1,289
    6
    2 Post(s)
    agree with foosa
    "THE BEGINING IS ALWAYS TODAY"
  20. #20
    mamehmood's Avatar
    Sep 2008
    702
    @abdulsattar
    Model: Aprilia RS 50 Year: 2005
    Category: Sport
    Rating: 74.9 out of 100. Show full rating and compare with other bikes
    Engine and transmission
    Displacement: 49.70 ccm (3.03 cubic inches)
    Engine type: Single cylinder
    Stroke: 2
    Bore x stroke: 40.3 x 39.0 mm (1.6 x 1.5 inches)
    Fuel system: Carburettor. Dell’Orto PHBN 12 - HS
    Ignition: Electronic, capacitor discharge
    Starter: Electric
    Cooling system: Liquid
    Gearbox: 6-speed
    Transmission type
    final drive: Chain
    Clutch: Multiple disks in oil bath
    Physical measures
    Seat height: 810 mm (31.9 inches) If adjustable, lowest setting.
    Chassis and dimensions
    Frame type: Sloping twin spar in cast aluminium with thin walled structural shell and cross rib reinforcement
    Front suspension: Aprilia Ø 35 mm central pin hydraulic telescopic fork.
    Front suspension travel: 110 mm (4.3 inches)
    Rear suspension: Double member swinging arm in high strength steel with hydraulic monoshock,.
    Rear suspension travel: 120 mm (4.7 inches)
    Front brakes: Single disc
    Front brakes diameter: 280 mm (11.0 inches)
    Rear brakes: Single disc
    Rear brakes diameter: 220 mm (8.7 inches)
    Exhaust system: Catalysed
    Speed and acceleration
    Other specifications
    Color options: Multicolored
    Yamaha R-125  vs  Aprillia RS125 vs Honda CBR125 -931347
    Yamaha R-125  vs  Aprillia RS125 vs Honda CBR125 -931348
    Yamaha R-125  vs  Aprillia RS125 vs Honda CBR125 -931349
    Cell#: 0300-4007480
