Results 1 to 4 of 4
Thread: what will be the cost of santro 05 fuel pump
    m_kaisar's Avatar
    May 2006
    Faisalabad
    39
    833
    5 Post(s)
    Default what will be the cost of santro 05 fuel pump
    I m facing missing on patrol, want to change the fuel pump to someone good. kindly suggest any good brand and price.
    thanks
    The revolution is not an apple that falls when it is ripe. You have to make it fall.
    (Che Guevara)
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,959
    12 Post(s)
    well in efis any fuel pump assy can be used go for oem or otherwise DENSO BOSCH the best
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
    iceman's Avatar
    Aug 2003
    38
    261
    In Karachi, Used Fuel pump korean (only motor) can be found for Rs. 1000/- in sher shah.
    New Motor (Chinese) in good quality is available for Rs. 800/- at plaza market. (Saifee Autos 021-2724085) All Santro Parts Available with this guy. I've been buying from him since a long time.
    Hope it helps You ssoner or later.
    iceman's Avatar
    Aug 2003
    38
    261
    Well missing is not usually b'coz of the fuel pump, instead check for coils current. One of the multipoint coils might not be functioning properly.
