Results 1 to 2 of 2
Thread: Santro Plus Issue
    qparacha's Avatar
    Mar 2009
    86
    Default Santro Plus Issue
    Assalam o Aalikum Gius;
    I own a Santro Plus 2001. My issue is the Pick is not good at all on AC especially when on the second gear. Also it used burst ( Pataka maartee hai every now and then on first & second gear.
    I just got the tunning and all plugs and wire have been changed but still it creates problem. I have asked the CNG techinican to install the advancer but he refused it that it will not help at all.
    Can any one who have had experienced that kind of problem in the past?.
    I will be delighted if any one have suggestion to resolve the issue.
    Thanks
    shakaib's Avatar
    Sep 2007
    35
    well,
    I also own the santro Plus 2001. But its GX with EFI engine.
    I had the same problem, which was rectified by the GarageMaster behind the Urdu University Islamabad.
    He asked me to change the plug wire ( which I know you have already change), but when I replaced with the orignal one from Hyundai which was about of Rs1800, that solved my problem.
    does it misfire even on petrol?
    try reducing the spark plug gap. or check you plug wires resistances to check if it of any good.
    Good Luck
