Results 1 to 12 of 12
Thread: problem with my santro
    ahmedwasiq's Avatar
    Nov 2007
    Rawalpindi
    31
    396
    6 Post(s)
    Default problem with my santro
    dear experts
    need your help,i have a santro 2001 last week on my way to lahore motorway,cars head gaskit leaked,i got it replaced from balkasar
    the problem it,my car is not stabile on petrol
    Two of its injectors are not working (like there is no current on two injectors)
    checked all the wiring but vain
    any one can help me in this regard or suggest me some good workshop in islamabad or lahore
    callmejib's Avatar
    Jun 2009
    Rawalpindi
    29
    karakuram nazir motors- g-8, islamabad
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    if the centre pair of cylinders i.e. 2 & 3 are not working; your cam sensor is dead or the wiring to the cam sensor is chopped..
    ahmedwasiq's Avatar
    Nov 2007
    Rawalpindi
    31
    396
    6 Post(s)
    dear 1st & 4th cylinder is not working,there is no pulse in the wiring,but the wires are okay
    any one knows the price of CAM sensor ???????
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    firstly Im not your dear
    back to business
    the mitsi foot cam sensor is about 4000 - is located near the twin coil packs bolted with a 6mm bolt (10mm head)
    The 1 and 4 is usually due to misaligned timing belt, the ECU is not seeing proper TDC, did your mechanic put it back correctly, and not mauled the crank sensor wheel in progress - he may also have put the crank sensor wheel backwards, this also causes if to get out of time, do verify that you have full 12 volts at the injector plugs with ignition on
    Site Banned Follow
    Te3pu_ch's Avatar
    Sep 2007
    Gujranwala
    36
    538
    i guess cam sensor u will find from the hyundai spare parts not in the open market..!
    ahmedwasiq's Avatar
    Nov 2007
    Rawalpindi
    31
    396
    6 Post(s)
    sorry Xulfiqar
    electrician has disconnected the ECU (Computer) but he said its perfect
    then he check the wiring,but didnt find the breakage
    its working fine on CNG,what you suggest me ????
    What should i do ?????
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    the crank sensor wheel needs to be checked, check belt alignment and then check the trigger wheel for alignment
    c123pk's Avatar
    Apr 2005
    40
    12,622
    10 Post(s)
    @Ahmed Wasiq, brother you have to be cautious here, people dont even like to be called "Brother" or "Dear" around here, dont take such replies to your heart, they have become machines in this materialistic world thumbs down to them from my side !
    gulouna's Avatar
    Mar 2008
    Peshawar
    35
    119
    How much did the cars head gaskit replacing cost? Did u notice any leakage or just due to low eng oil level?
    Bringing a Revolution in Driving
    babertasleem's Avatar
    Jul 2006
    28
    148
    @ahmed wasiq bhai
    ap wiring cheak kerwain yaa apke sensor mein garbar hai m,cheak light arahai hai
    U MUST UNDERSTAND 1 SIMPLE FACT. . . IT IS NOT DIFFICULT TO CATCH ME , ITS IMPOSSIBLE ! ! !
  12. #12
    chinyoti's Avatar
    Sep 2005
    27
    11,949
    5
    105 Post(s)
    5 Thread(s)
    if the calm shaft sensor isnt working the car shud give check engine light mayit be on CNG or Petrol.
    secondly is ur car a local CNG? or Factory fitted, local cng people mostly cut the calm shaft wire to give current to the advancer. this has hapned wid me in the case of my Baleno.
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
