Results 1 to 10 of 10
Thread: Santro Club Hi RPM problem
    mgwattoo's Avatar
    Mar 2009
    32
    34
    Default Santro Club Hi RPM problem
    The RPM of my Santro club is really very high. I think the RPM should be around 750 rpm but my car's RPM are about 1100.
    Is this because of any censor or any other issue and whta's the best place to go for solving the issue(Mechanic/Workshop/Hyundai Showroom) ?
    riz_'s Avatar
    Sep 2007
    Select City
    50
    6,175
    8 Post(s)
    Are you talking about idle RPM?
    Are there any accessories that are turned on when you are observing higher RPM?
    My opinions, suggestions and thoughts are strictly my own. I reserve the right to be human and make mistakes.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3990 Post(s)
    94 Thread(s)
    6
    this is a very common problem, you need to remove the whole inlet manifold and wash it and especially the idle motor itself.. If you are shy to remove the B1tchy manifold just remove the idle motor and wash it with carb cleaner - and apply oil to it, it will start to function, also while at it, check the coolant temp sensor wiring if its crusted or broken off
    mgwattoo's Avatar
    Mar 2009
    32
    34
    Sorry i don't know about some things which u have mentioned in ur post.
    1. inlet manifold ?
    2.idle motor ?
    and the best mechanic who can do this without asking "thousands" ?
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3990 Post(s)
    94 Thread(s)
    6
    the inlet manifold is the 4 branch solid thing that feeds the engine with fresh air after the throttle has let it in, The idle control motor is the little 3 pin motor that allows extra air in the manifold to let it idle properly - its can be above the throttle body or near the 1st cylinder branch of the inlet manifold in a santro.
    btw im in Karachi - cant say about Lahore - no offense but of all the lahore cars that were shipped to me for repairs had weird jobs on them.
    thinkali's Avatar
    Sep 2005
    Hyderabad
    40
    42
    well check the condition of the air filter... if dirty replace... take out one battery terminal i-e disconnect battery... then reconnect after ..say 2 mins.
    gulouna's Avatar
    Mar 2008
    Peshawar
    35
    119
    My santro 2004's rpm is also very high .. I will be InshaAllah going for a computerised tunning where I'll be reducing it..Last time while tunning the mec did reduce it but as I had just purchased it so was not familiar with its rpm so I codnt inform him of reducing it a bit more.. Well it all cost rs 150 only included is plugs n air filter cleaning + computerised tune ups...
    Try this 1st it will InshaAllah help n u'll nt need any big works of thousands...
    Bringing a Revolution in Driving
    atharhasan's Avatar
    Sep 2009
    36
    48
    dear where you give rs150 for the tuning of santro.......... ? well in hyundai sawan motors they took rs500 and also in hundai mirpur AJK they took rs 500. but my personal experience is that hyundai mirpur were good.
    athar hasan
    03337866862
    IHateRollas's Avatar
    Jul 2011
    475
    Clean the throttle body
    Jul 2011
    475
    Santro Club Hi RPM problem -1089149
