Results 1 to 13 of 13
Thread: Santro Speed Throttle Stuck
    sasadmunir's Avatar
    Oct 2009
    33
    11
    Default Santro Speed Throttle Stuck
    I have recently purchased a 2002 model Santro Plus (MPFI). This type of model did not come with CNG Kit installed. The person from whom I have bought this had the CNG Kit fitted later, manually. The problem is that on petrol the car remain in high RPM even when idle, as if its speed throttle is stuck. When on CNG it behaves the same except that after 5 or 6 seconds the RPMs returns to the normal range. This constant high RPM are also causing a little bit of over heating. The accelerator pedal wire is fitted right, I have checked it under hood as well. Don't know what's the problem. Could it be the ECU?
    wala's Avatar
    Mar 2005
    27
    309
    choke sensor fault....
    wala's Avatar
    Mar 2005
    27
    309
    or some say throttle sensor.... its the samething. try cleaning it. it usually resolves it...
    sasadmunir's Avatar
    Oct 2009
    33
    11
    Quote Originally Posted by wala View Post
    Can ordinary workshops deal in such stuff or should I take it to the authorized dealers only?
    fasfas's Avatar
    Oct 2007
    Wah cantt
    38
    359
    Hi,
    From Carby point of view, there can be two things affecting,
    bcoz there would be some alternate function made in MPFI.
    1 - There is one Screw in throttle that adjusts the speed (accelerator related), that might need to set.
    2 - There is one throttle screw that is used to fix the Stand-By fuel. This one is long one. In Khyber, I need to get closer than brake drum/viper connection to see it rightly.
    Site Banned Follow
    Zeejigs's Avatar
    Aug 2006
    Rawalpindi
    30
    3,121
    ^^i am facing this problem in khyber!!its rpm increases on petrol and on cng it remains fine!!plz tell me what to do???
    sasadmunir's Avatar
    Oct 2009
    33
    11
    Quote Originally Posted by fasfas View Post
    Hi,
    I know that you are referring to but as I said the throttle returns to the normal stage once its idle for 5 to 6 seconds. Which means that the screws are okay at their place. It's probably something inside the engine that is reading the values wrong. Probably what "wala" might be referring to. I update the thread once I get it checked up.
    irfansiddique's Avatar
    Oct 2008
    33
    1,765
    12 Post(s)
    Throttle body service - main and first thing u should all go for.
    wala's Avatar
    Mar 2005
    27
    309
    Quote Originally Posted by Zeejigs View Post
    adjust the petrol idle screw on your car's carb....
    fasfas's Avatar
    Oct 2007
    Wah cantt
    38
    359
    Quote Originally Posted by sasadmunir View Post
    Find someone with good Electronic Mastery not only mechanic and I think you need to search.
    As EFIs and MPFIs are electronically controlled and someone who reads and knows the measurement of electronic signals.
    cloud100's Avatar
    Dec 2009
    29
    927
    bro get ur car tuned then it will go away + get ur carb cleaned,
  12. #12
    Proverbial_Slang's Avatar
    May 2005
    3,903
    29 Post(s)
    Bro, the general rule is to get the engine adjusted for petrol first, and then adjust CNG according to that. So get it tuned first.
    Death is not the greatest loss in life. The greatest loss is what dies inside us while we live.
  13. #13
    ngen's Avatar
    Oct 2008
    38
    166
    you have an air leak in your intake area. look around the area where the cng pipe goes into the throttle, normally has silicone all around it. check it yourself or get it checked. nothing wrong with your ecu.
Tags for this Thread
