Results 1 to 16 of 16
Thread: Water in gear oil (santro)
    ehsaniuk's Avatar
    Apr 2006
    Peshawar
    42
    335
    Default Water in gear oil (santro)
    Dear Experts
    Yesterday i came across a very strage comment made by hundai mechanics at their workshop while they were working on a santro car. According to them, most santro cars have a congenital problem in which water (from somwhere) intrudes into its gear box making gear oil milky. If car is run afterwards for extended periods of time, gear box may completely fail.
    Can someone shed a light on this issue. I am worried coz i myself own a santro...
    ehsaniuk's Avatar
    Apr 2006
    Peshawar
    42
    335
    bump
    ZubairMughal's Avatar
    May 2010
    Rawalpindi
    54
    Sawan Motors Rawalpindi (G.T. Road), fail to do my this problem, they charge Rs 4500, but the MILKY GEAR OIL is still there.
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    moisture in the transmission fluid is death. seems to me that there is a leak in a seal somewhere which is allowing air/moisture to enter the casing and then the gears are churinging up the mixture which is causing hte fluid to go milky.
    this leak should be tested with UV dye and a UV light.
    ngen's Avatar
    Oct 2008
    38
    166
    i got a santro club too in my workshop with the same problem ... tried 2-3 different things but still same problem, its a tough one to fix.
    IBAAD's Avatar
    Sep 2006
    26
    73
    i was having same problem in my santro club. but i got the oil changed,but still dont got it that why this is happening??
    voodoo's Avatar
    Jul 2004
    37
    667
    3 Post(s)
    i had the same issue... it just got resolved by its own self... i do regurarly get the oil checked.
    iiqbal's Avatar
    Nov 2006
    38
    2,121
    2 Post(s)
    Quote Originally Posted by voodoo View Post
    how u can check the gear oil ?
    Imran Iqbal
    ngen's Avatar
    Oct 2008
    38
    166
    have you guys tried changing the blowby valve?
    voodoo's Avatar
    Jul 2004
    37
    667
    3 Post(s)
    the blowby value... not sure abt that... but i did get the full car checked and there where no signs of leakes
    Horse_rider's Avatar
    Sep 2009
    30
    1,363
    3 Post(s)
    what is a blow by valve? is it the valve called PCV valve in the santro? (positive crankcase ventilation valve)
  12. #12
    ngen's Avatar
    Oct 2008
    38
    166
    it's not the pcv ... works like the pcv but is location on the gear box ... to allow gases/moisture to escape.
  13. #13
    Sep 2009
    30
    1,363
    3 Post(s)
    @ngen
    thanks man
    what is the local name of PCV valve i have asked many workshops and auto shops but they dont know PCV Valve, is there local name? plz guide
  14. #14
    VCheng's Avatar
    May 2010
    Select City
    25,475
    7
    434 Post(s)
    4 Thread(s)
    Quote Originally Posted by ngen View Post
    It is called a Transaxle Breather Tube assembly but I have no idea what the "local" name might be.
  15. #15
    ngen's Avatar
    Oct 2008
    38
    166
    local name for PCV: "one way valve" on the tappet cover... most will understand what you mean... although very few know the actual funtion of the valve.
  16. #16
    ngen's Avatar
    Oct 2008
    38
    166
    Quote Originally Posted by VCheng View Post
    that's the one ... thanks vcheng. i think the local name for this is the blowby pipe on the gear.
