Results 1 to 4 of 4
Thread: Santro cng to petrol problem
    voodoo's Avatar
    Jul 2004
    37
    667
    3 Post(s)
    Default Santro cng to petrol problem
    hey all
    i have a santo model 2008 which is done approx 36500km. till yesterday the car was running fine.i drive the car on petrol once a week all day. it used to start on petrol and then automatically convert to cng. but now its not working on petrol anymore. i have to directly start the car on cng. the car on petrol keeps on choking and feels like as if there is not enough fuel comming in it also when on petrol the exaust also smells as if its not burning the fuel properly, while on cng the car is running perfect. my car used to take water from cylincer on both petrol and cng. need help on how to fix the petrol problem.
    Thanks
    TotaLOverdosE's Avatar
    Sep 2006
    25
    963
    ^^ Shut of the main CNG cylinder valve completely !
    Then try starting it on petrol, if this works then i guess your problem is pretty obvious
    Never chase a lie. Let it alone, and it will run itself to death - Lyman Beecher
    voodoo's Avatar
    Jul 2004
    37
    667
    3 Post(s)
    issue has been resolved. the problem was with the pipe connecting the fuel pump which was leaking and therefore was unable to pump with the required pressure.
    jaggi's Avatar
    Jan 2009
    26
    7,324
    50 Post(s)
    2 Thread(s)
    ^^3years ago I had the same prob in ma santro.
