My question is clear from the thread, and if yes what are the advantages/disadvantages of removing it. Any users who have experienced it please share in this forum...thanking in advanceadeel
highly doubt it
catalytic converter just helps in removing harmful emissions thats the only advantage the disadvantage is that it may get clogged up in cars like the RX8 etc. (to stop it from clogging u have to rev to max limit once a month)
Thanx for your input @illdude786 & @AmmarFaiz..But my question still remains unanswered....I need first hand information for Santro only.RegardsAdeel
Bump....
ammarfiaz is right
@Iamadee
I Think there is no catalytic converter in santro. advantage and disadvantage is stated by the AmmarFaiaz. if it get clogged then the pick will be suffering. i saw some threads about vitz at pakwheels, in which some vitz owners removed the CAT.
https://www.pakwheels.com/forums/engine-transmission-powertrain/110964-catalytic-converter-there-my-car
https://www.pakwheels.com/forums/d-i-y-projects/73794-removing-catalytic-convertor-cat-vitz-yaris
https://www.pakwheels.com/forums/engine-transmission-powertrain/54531-found-vitz-catalytic-converter-remover-shop-khi
https://www.pakwheels.com/forums/miscellaneous/66209-help-required-vitz
I know that there is no information about the santro CAT, but there will be some advantages and disadvantages of CAT.
i have gone through all of these forums but no first hand information on santro was found... well maybe that means a no. I just wanted to know if someone had first hand info or personal experience with it...anyways thanx all for helping..my question still exits if someone has info on it...
no catalytic converter in santro(all variants)
@irfansiddique
Thanx bro for sharing the information.Thanx all.
@mods please close the thread.
