Results 1 to 7 of 7
Thread: Santro - Cam Sensor
    a_k
    a_k is offline
    a_k's Avatar
    Feb 2005
    39
    2,015
    4 Post(s)
    Exclamation Santro - Cam Sensor
    My Santro, 2003 got problem, it was running fine I parked it in my home and next morning when tried to start, engine was like missing, initially mechanic diagnosed it as faulty injector, later on scanning found out to be Cam Sensor ! Replaced & running fine, <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o:p></o:p>
    <o:p></o:p>
    My question is how the hell check engine light never warned me, even when the mechanic was checking it was functioning normally??!?!?<o:p></o:p>
    <o:p></o:p>
    Should I get wiring checked? or what else could be the problem?<o:p></o:p>
    <o:p></o:p>
    How many more sensor(s) are not linked to check engine light?<o:p></o:p>
    <o:p></o:p>
    Thanx in advance<o:p></o:p>
    If better were within, better would come out.
    a_k
    a_k is offline
    a_k's Avatar
    Feb 2005
    39
    2,015
    4 Post(s)
    hello
    osama96's Avatar
    Jun 2008
    Riyadh
    26
    2,659
    2 Post(s)
    Engine light only indicate low level of engine oil it has nothing to do with cam sensor
    Beshak ALLAH he sy hy sub waqt sy pehly nahin zarorat sy zada nahin.
    vagabondpiper's Avatar
    Jun 2010
    34
    1,328
    23 Post(s)
    r u sure that check light is serviceable? does it illuminate during lamp test?( that is when u give the ignition for starting and all dash lights come on)
    No one cares for Toyota more then Toyota
    a_k
    a_k is offline
    a_k's Avatar
    Feb 2005
    39
    2,015
    4 Post(s)
    check engine indicator is there to lit up if there is any problem which is connected to ECU via sensor, (my limited knowledge), when we switch ignition on it turn on and after few seconds it turn off, it mean that every thing is fine,
    now in my above case check light functions as normal , question is why?
    VCheng's Avatar
    May 2010
    Select City
    25,478
    7
    434 Post(s)
    4 Thread(s)
    The paramters for setting the MIL to ON may not have been met as defined by the manufacturer.
    tauxeef's Avatar
    Jun 2010
    Dubai
    28
    901
    Quote Originally Posted by a_k View Post
    u r rit
    a programmer, webmaster, electronics enthusiast, traveller, adventurer, gizmo's freak by hobby & an electrical engineer by profession tauxeef.com
