Results 1 to 12 of 12
Thread: Cam Sensor Santro
    m_kaisar's Avatar
    May 2006
    Faisalabad
    39
    834
    5 Post(s)
    Default Cam Sensor Santro
    Want to know if this is the original one or after market.
    some days back bought same with different label(written in white) but that was not detected by hyundai scanner. will get this replaced today and will update the progress.
    problem was missing on patrol as some threads already created but got no solution for this as everything has been done.
    Cam Sensor Santro -189370
    Cam Sensor Santro -189371
    Cam Sensor Santro -189372
    Cam Sensor Santro -189373
    Cam Sensor Santro -189374
    Cam Sensor Santro -189375
    Cam Sensor Santro -189376
    Cam Sensor Santro -189377
    Cam Sensor Santro -189378
    Cam Sensor Santro -189379
    Cam Sensor Santro -189380
    The revolution is not an apple that falls when it is ripe. You have to make it fall.
    (Che Guevara)
    evo90210's Avatar
    Jan 2011
    33
    386
    whats this used for?.
    *(King Evolution)*
    m_kaisar's Avatar
    May 2006
    Faisalabad
    39
    834
    5 Post(s)
    The cam sensor tells the computer where your cam is in it's rotation. The info is used to determine spark timing and fuel delivery. if it's bad, you'll run rough or not at all. Vehicles with distributors will sometimes integrate thet sensor with the distributor. Otherwise, it will be located near the cam.
    Read more: Answers.com - What is a cam sensor and how do you know when it is going bad and where would you look for it
    (Che Guevara)
    m_kaisar's Avatar
    May 2006
    Faisalabad
    39
    834
    5 Post(s)
    no one knows?
    (Che Guevara)
    bilalbinrais12's Avatar
    Sep 2008
    Kwangju
    28
    176
    dont worry. it works. I have santro 2004. was good an cng but was missing and terribly shaking on petrol. got one cam sensor changed as diagnosed by hyundai rawalpindis diagnostic station. It seems to be the same as u posted. hope it will work
    Sep 2008
    Kwangju
    28
    176
    For more info 0333-5957416
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    When this sensor fails on your santro, no.2 and no.3 cylinders will not work on petrol (no fuel). Its located on the end of the head.
    This same part is also on Suzuki Baleno same location same purpose.
    This is also used in mitsubishi engines/transmissions
    m_kaisar's Avatar
    May 2006
    Faisalabad
    39
    834
    5 Post(s)
    @Xulfiqar
    thanx for reply.
    what would be the other reason for missing on patrol even after changing the cam sensor, missing is there in slow speed, not feel in higher gears like 3, 4, but in fist and second it gives jerks and in idle condition rpm remains smooth.
    this problem is only on patrol, on cng its ok.
    (Che Guevara)
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Quote Originally Posted by m_kaisar View Post
    @Xulfiqar
    thanx for reply.
    Have you checked plug, plug leads, coils, distributor?
    Keep a cool head and wear seatbelts!
    m_kaisar's Avatar
    May 2006
    Faisalabad
    39
    834
    5 Post(s)
    plugs, plug cables changed to new one.
    mechanic did'nt tell any problem regarding coils / distributor.
    (Che Guevara)
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    your issue can be pointed to
    incorrect fuel pump pressure
    clogged injectors
    coated/oily MAP/IAT
    remove the inlet manifold and have it washed out - remove injectors and have them cleaned out too
  12. #12
    m_kaisar's Avatar
    May 2006
    Faisalabad
    39
    834
    5 Post(s)
    fuel pump ok
    map/iat cleaned
    only injectors remain for test.
    dont you think it may be timing belt issue....... as i had recently changed my timing belt to not original one but of after market one due to emergency on the way.
    (Che Guevara)
  13. 28-07-2012, 08:51 PM
    PakWheeler
Tags for this Thread
