Results 1 to 5 of 5
Thread: can i install check engine light system in my santro 2003
    Horse_rider's Avatar
    Sep 2009
    30
    1,363
    3 Post(s)
    Default can i install check engine light system in my santro 2003
    all santro has check engine light except 2003-2004 model, i have 2003 club, which dont have check light.
    my question is if all the systems including engine and all other accessories are the same for all models, then why only these 03-04 dont have check engine light? and is there any possibility to install this system? if yes then how?
    현대 애인
    Vaqas1's Avatar
    Nov 2004
    5,267
    6
    49 Post(s)
    do you see any check light place in your speedo meter area? Which is disabled?
    You will have to take its ECU out and than hook up check engine light. But there must be a reason why it was not given in this model.
    Speed costs money, how fast can you afford to go.
    salahuddin10's Avatar
    Apr 2006
    32
    104
    Bro I ran in to same problem once, all I did was I took out the meter and installed a bulb at the check engine light slot and it worked. Actually Hyundai pakistan removed this light due to some ecu main relay issues the car used to through checks after some time i dont know know wat they were as it nvr effected the driveability.
    Sep 2009
    30
    1,363
    3 Post(s)
    yes that light is look like removed, because the bulb holder is there for the bulb to install. i will Inshallah install bulb, hope it will work for me.
    현대 애인
    Sep 2009
    30
    1,363
    3 Post(s)
    Thanks to everyone, if someone have more experiences to share then please do share your experience.
    현대 애인
  6. 28-07-2012, 05:50 PM
    PakWheeler
Tags for this Thread
