Results 1 to 13 of 13
Thread: ENERCON advice replacing Santro plug wires
    Nasir_usman's Avatar
    Aug 2010
    27
    42
    Default ENERCON advice replacing Santro plug wires
    today i have visited ENORCON Islamabad for CNG tuning, and my car's RPM was fluctuating around 1850 RPM constantly between 1800-1900.
    he did not tune my engine rather he told me to change plug wires, so i want to know is it good to change plug wires? and if yes then should i go for performance wires or stock one?
    what will be the price for santro plug wires? as i did not buy any wires yet. and this is my first car.
    experts please help.
    Thanks
    speedster_101's Avatar
    Sep 2005
    3,447
    54 Post(s)
    Did he check the plug wires with a help of meter?
    These wires have some specific resistance and you need to replace them when their resistance is increased beyond prescribed limit.
    "The more we sweat in peace, the less we bleed in war"
    Aug 2010
    27
    42
    they did not check the wires with meter, but told me that bosch super 4 tip has cause the stock plug wires short or weakened. i want to use these 4 tip plug so should i go for performance wires?
    and what will be the price.
    bilal49er's Avatar
    Jan 2005
    Hyderabad
    40
    1,542
    Quote Originally Posted by Nasir_usman View Post
    nonsense and bul#hit!
    most shade tree mechanics here assume that 4 tip makes 4 sparks so overload or stresses the coil and wire this is crap knowledge!
    4 tips only ensure that spark occurs from ANY 1 of the tips and the plug doesnt misfire during load / performance..go ahead with bosch 4 tip platinums..
    sent from my HD2 without using the handset itself!!
    zank's Avatar
    Feb 2009
    36
    1,484
    21 Post(s)
    Now, you should change your mechanic!
    If you really need to change plug wires, you can replace with Ultima Sports 8mm (yellow one). It will cost you around Rs. 800 to 1000
    Bosch 4 tips are fine, you can keep using them. Though it will not really boost up the performance at all, but still are better in other terms.
    Aug 2010
    27
    42
    Thank you all specially for the name of wire plugs, changing was recommended by ENORCON
    Sep 2005
    3,447
    54 Post(s)
    My experience with ENERCON G10 Islamabad is also not good.
    They say that we have all sorts of computerized equipment, they should have checked the plug wires resistance.
    devilz_apprentice's Avatar
    Apr 2006
    26
    2,840
    23 Post(s)
    ENERCON's mechanics are morons! Same is the case here in LHR. ENERCON became popular here in LHR because one man named Yasim but he has left them and started his own setup. All the other ENERCON mechanics simply don't know anything at all regarding tuning.
    My understanding dictates that all the plugs of the same heat range and same core material will draw exactly the same amount of current through the plug wires so the scenario of plug wires getting heat-up due to one specific plug is out of question. Though plug wires do deteriorate with time as the resistivity per unit length does not remain uniform so replacing them is a good practice. However, replacing stock plug wires with after-market, performance wires will ensure a better conductance of the current as compared to the stock wires. Hence the idle rpm of the car will be much more stable. These are just my two cents and experts are welcome to correct me.
    One question from the experts: Do 5-heat range platinums draw the same amount of current as compared to 5-heat range copper plugs?
    Bumper Sticker: "I feed off other people's rage, so drive carefully :-)."
    cracked's Avatar
    Mar 2009
    Rawalpindi
    28
    2,962
    35 Post(s)
    mechanic said 4 tip plugs have over burdened the wires?
    LMFAO..
    4 tip dont means they carry 4 times the spark,it means it has four hands to catch the spark,the BEST hand catches the spark every time so the spark goes thru wire is same as single tip..
    u shud have left the shop as soon as u heard this mystic views of his!
    REAL men drive manual cars!
    Aug 2010
    27
    42
    Today i dirive the car on petrol after visiting that ENERCON, and the car was missing a lot on petrol in 1st second gears. before that visit everything was fine, the car is now ok on CNG but missing on petrol, ideling is ok on CNG but very rough and fluctuating on petrol. what is the problem?
    Subzwari's Avatar
    Mar 2009
    36
    415
    bad injectors ...may be...try some injector clean up services as available at Liqui Moly.
  12. #12
    Aug 2010
    27
    42
    Quote Originally Posted by Subzwari View Post
    Thanks
    how much that liqui moly injector cleaning will cost?
    or i should use STP ijectors.
  13. #13
    Subzwari's Avatar
    Mar 2009
    36
    415
    STP is usually not worth it.....a bottle will cost your around Rs. 250-300. Whereas Liquimoly service is close to Rs. 1000. But that's not as simple pour-in-the-tank solution...they hook up their gadgets to the injectors and disconnect the fuel lines from the tank...the complete process will take around half an hour....i myself has not experienced but talked to a liquimoly chap some long time ago...call this number 0345-5912364 051-2823016. they are located near China Chowk, Poly clinic.
  14. 28-07-2012, 08:54 PM
    PakWheeler
Tags for this Thread
