Results 1 to 14 of 14
Thread: Is auto gear box for Santro 04 available?
    R.I.P. Follow
    mirza_yasir's Avatar
    Jul 2006
    34
    2,374
    Question Is auto gear box for Santro 04 available?
    Can a Santro Manual 2004 model be converted to auto transmission. Is there auto gear available for it in the market.
    R.I.P. Follow
    Jul 2006
    34
    2,374
    ibadaslam872's Avatar
    Feb 2009
    18
    6,103
    5
    49 Post(s)
    It should be possible.
    A fellow member converted Mehran from manual to Auto.
    Try going to the market and asking the 'Ustad's' if they can arrange one for you.
    Under the Coconut tree
    R.I.P. Follow
    Jul 2006
    34
    2,374
    I know about mehran and other commonly available japanese car conversion, but this santro thing is above me as i dont think so that its auto gear box will be available as its korean based and its parts may not be imported in scrap, thats why i needed expert opinions from Gurus here.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    yes it is - you would need a completely new engine wiring harness too as the transmission is sourced from mitsubishi it is electronically controlled. - If you get the complete wiring - its a plug and play situation.
    The issue most people face is that their original engine ECUs are different from the ones that the junkers have - hence the wiring harness is different.
    R.I.P. Follow
    Jul 2006
    34
    2,374
    ^Is this situation is in Pakistan??
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    yes - in Pakistan. the older (shoe shaped) santro is easier to do.
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    @poster no need of chaging engine the total setup of auto transmisn of hyundai autos(santro in pak) is availabl in market all u hv to do is to get the trnsmsn fitted inn wiring etc etc...the cmplete setup includes the console(gear console i mean)nd it fits jst like bolt on in the car.
    here in fsd it costs about 20,000.
    ''Peace is an unstable equilibrium,that can only be preserved by acknowledged supremacy and...equal power.'' ''We give up the fort when there is not a man left to defend it.''
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    @xulfiqar bro thrz no need of any mitsubushi's setup.santro's original auto transmision is available in market.
    R.I.P. Follow
    Jul 2006
    34
    2,374
    thanks for responses brothers.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    Quote Originally Posted by immad100 View Post
    What I said is that the engine and transmission used in your Santro are both from Mitsubishi - and require their original TCM (trans control Module) to run.
    If you just bolt it and dont wire it up - it will forever remain in 3rd gear and never ever shift. To make it function i.e. shift correctly you need the original wiring harness as in the manual car there is only one ECU - in the auto car there would be two units, an ECU and a TCU on top of it.
    The TCU takes various signals from the ECU and is spidered into the wiring harness - SO THAT IS WHY you need a whole wiring harness. If you go look around you will find that the newer plastic case ECUs with 4 plugs wiring is not available readily but the older style, metal case ECU with 3 plugs is plenty (this setup came in the shoe shaped santro). Thats why I said its much easier.
  12. #12
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    @xulfiqar ooooooo....
    got it so buddy wht is that they cal wiring then???(i mean the they say gear,fitting,WIRING will cost around 20,000)
  13. #13
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    If they offer full wiring up of the transmission its a good deal - BUT MAKE SURE FIRST that you tell them the transmission should shift into all ratios and also convertor lockup.
    Fitting the unit is the easy job - getting it to work correctly is another and not so easy job. How do I know - Ive swapped out many Automatic tranny GDI galants to V6 engine/automatic trannys from similar Legnum/Galant scrap units.
    And sorting out the wiring is not so much fun - specially if you also want it to be semi-manual (aka tiptronic) - did that in Galants and it was massively cool.
  14. #14
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    thnx buddy i got it....!!
