Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By imranbhatti
Thread: santro belts querry (seek your guidance)
    ehsaniuk's Avatar
    Apr 2006
    Peshawar
    42
    335
    Default santro belts querry (seek your guidance)
    Dear All
    I got timing belt, generator belt and ac belt (of 04 santro executive) replaced three weeks back. All seems fine except squeaky noise that arise ONLY (most probably belt noise) when steering wheel is rotated and when it reaches its end point. Noise arises when steering fully rotates to both sides. Then, when it is counter rotated even a bit, noise vanishes. I am really seeking your guidance on the issue
    Regards
    Ehsan Inam Ullah
    Automotorsport_Lover's Avatar
    May 2008
    25
    3,834
    5
    82 Post(s)
    6 Thread(s)
    Probably its the generator belt making noise... When the steering wheel is turned fully, load on generator is increased(power steering) and it starts making noise..
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    Santro Exec have hydraulic power steering & U must had replaced PS pump belt too & that might be causing problem.
    Exploring Machines is my Passion...
    ehsaniuk's Avatar
    Apr 2006
    Peshawar
    42
    335
    Thanks for your guidance, but please also suggest what should be done
