Results 1 to 6 of 6
Like Tree4Likes
  • 3 Post By Xulfiqar
  • 1 Post By Sharo53
Thread: santro starting problem...
    cammander's Avatar
    Sep 2011
    27
    49
    Default santro starting problem...
    aslaam o alikum.
    guys i am new here..
    meray pass santro gv hai.. jab me usay kuch dair chalanay ka baad car ko off kar ka dobara 2min ya 5min baad start karta hoon to start nae hotii. to thora dhaka lagana parta ha.. ya jab us beam lights or a.c on rah jae n car ko off kar ka dobara start karon to start nae hotiii...
    agar half hour ka baad start karon to load la kar start hoti haii.....
    mei na electrician ko dikhaya ha.. us nae pehlay us ka sulf repair kya.. to kuch din car sahi chalii. per ab dobara waisay he kar rahi ha.. to me nae electricaian ka kahnay per battery bhi replace kar de ha.. but abi bhi problem haiii...
    what sould i do know???
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    check the negative battery cable to the transmission case.
    Sharo53's Avatar
    Nov 2009
    25
    2,414
    23 Post(s)
    battery negative say gari ki chassis tak, aur phr chassis sau gearbox tak moti taar lagva lain...
    .........Tomorrow Never Comes Until Its Too Late........
    //////Life Without LOUD Sound System iz incomplete\\\\\\
    cammander's Avatar
    Sep 2011
    27
    49
    thnx Xulfiqar and Sharo53 it seems problem solved.....
    faacs's Avatar
    Dec 2010
    11
    I have same problem, When cold, car starts on first sulf. After running some 20-30, if you turn off and then try to sulf start again. sulf seems jamed. If I try again after letting it cold say 30 mins, it agains starts on first sulf. is this also negative terminal issue? Help guys main dhaka lga lga k thak gya hon
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    seems like it, get a good branded battery terminal (SNA make them) - now find good quality automotive purpose wire, cut it long enough for it to reach the starter mounting ear neatly, now peel off some insulation from the middle of the wire and make a branch of to attach to the body of the car, Solidly crimp lugs onto the wire ends. (best ground cable)
    Do not use oversize wire as it may hinder current flow.
