Results 1 to 12 of 12
Like Tree6Likes
  • 1 Post By yaarfarooq
  • 3 Post By Xplorer
  • 1 Post By immad100
  • 1 Post By capsat
Thread: Do I need a complete overhaul? (Santro Exec)
    zaheerkhan's Avatar
    Mar 2010
    Rawalpindi
    30
    92
    Default Do I need a complete overhaul? (Santro Exec)
    Hello guys,
    I own a Santro Exec 2005. Recently I ran into this problem. The engine gives a sound on hard acceleration. I get most of the work done from Hyundai Sowan Motors Rawalpindi. I asked one of the guys there and he told me that this is a crank sound and it can only be fixed by overhauling.
    Symptoms:
    Engine turns heavy even on 10KM/hour and sound starts coming. I won't call it noise because the sound is hardly noticeable.
    No oil decrease issue.
    No smoke issue.
    Timing belt recently changed.
    The mechanic said that I should keep the car running. I won't need overhaul in next 1.5 years provided that I don't hard accelerate. BUT that's not the solution. I highly suspect that complete overhaul is necessary in this case.
    Is there any way that only crank can be repaired? I fear, that if I keep on running the car in this condition, that would wear pistons, valves, rings and other stuff in the engine.
    Suggestions highly appreciated.
    Thank you
    PS: btw they gave me an estimate of at least 65K for complete overhaul.
    PPS: Please recommend me a good mechanic in Rwp/Isb who is dedicated and committed to his work.
    CarSpa.pk - Online Car Store
    yaarfarooq's Avatar
    Mar 2009
    40
    182
    Consult with atleast 3 mechanics than make final decision.
    Also check the Hyundai Santro fan club on Pakwheels forums. read all the pages you will get some names of mechanics & info about other related issues.
    Xplorer's Avatar
    Oct 2007
    41
    790
    10 Post(s)
    This is only crank issue.
    If there is nothing wrong with pistons and head, then only crank can be repaired in 5 to 6 k. However engine is to be taken out of the hood and then crank will be accessible.
    Say NO to OPEN LETTERS
    zaheerkhan's Avatar
    Mar 2010
    Rawalpindi
    30
    92
    Quote Originally Posted by Xplorer View Post
    Can you recommend any good mechanic?
    Horse_rider's Avatar
    Sep 2009
    30
    1,364
    3 Post(s)
    Might be the issue is not with crank. check with other mechanics as well. the engine goes heavy both on A/C and without A/C?
    If only with A/C then check your A/C. otherwise check from other mechanics.
    현대 애인
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    65k of genrl overhaul?????
    it hardly costs about 28k.
    btw run it as it is until or unless it gives smoke or decrease oil.
    ''Peace is an unstable equilibrium,that can only be preserved by acknowledged supremacy and...equal power.'' ''We give up the fort when there is not a man left to defend it.''
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    nd yeah if thrz crank issue thn it can b replaced too without doing any punga with other things..
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    yaar first make sure that its not Valves issue as Santro has an issue when you keep on running it on CNG the valves gets burnt and this problem occurs and it make sound like as if its crank's sound .... i dun think its your crank issue ....
    ~ Be a responsible citizen and always drive safely ~
    Xplorer's Avatar
    Oct 2007
    41
    790
    10 Post(s)
    Crank noise can be easily recognized. Any experienced mechanic can identify it.
    Take it to any trust worthy mechanic (not the dealership) and your problem will be rectified.
    tauqir20's Avatar
    Mar 2008
    Rawalpindi
    40
    13
    complete overhaul of Santro takes around 30000.
    there is a mechanic Javed near Double road intersection (workshop near pindora) on I J Principal road.
    Contact him.he is a honest man and will give you good advice.
    usually he takes 5 to 6 thousand for complete overhaul.
    Contact No 0301 5507452
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    Red face
    does this SOUND started after the timing belt is changed ? IF YES - something is not fixed back properly.
  12. #12
    Newbie Follow
    Sharjeeell's Avatar
    Aug 2008
    38
    change your engine oil with any good reputable company.
