Results 1 to 2 of 2
Thread: Install RPM Guage in Santro..
    waqasjamil's Avatar
    Aug 2006
    189
    4 Post(s)
    Default Install RPM Guage in Santro..
    Hello Brothers.. Can any one tel is it possible to install Tachometer/RPM guage in Hyundai Santro and if possible then which mechanic is best.?
    roms's Avatar
    Feb 2011
    33
    3,067
    5
    103 Post(s)
    Any good mechanic can install it without a problem, make sure u go to a reputed EFi electrician.
    Just for reference
    +12v power
    -ve For ground
    IG- is for Rpm signal from ignition coil
    Make sure u select 4cyl from the back of tacho
    Solar Hunter armed with a whip and a leash
