Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Like Tree8Likes
Thread: Santro engine Overhaul experts-LIANARULES
    ibadaslam872's Avatar
    Feb 2009
    19
    6,107
    5
    49 Post(s)
    Default Santro engine Overhaul experts-LIANARULES
    Salam PW's.
    My santro's engine may need to be overhauled in the coming weeks.
    Can anyone please name some well-experienced mechanics near D.H.A/Walton/Cavalry ground?
    The mechanic must be an expert in overhauling EFi engines.
    Thank you
    Under the Coconut tree
    Shicks's Avatar
    Jul 2007
    2,091
    76 Post(s)
    2 Thread(s)
    contact me
    0321-8886922
    Will guide u da best person , i have been with dat guy from last 17 years .... best guy i knw so far !!
    Feb 2009
    19
    6,107
    5
    49 Post(s)
    Quote Originally Posted by Shicks View Post
    contact me
    0321-8886922
    Has he done any Santro engines successfully?
    Thank you
    Have noted your number,Will call you once the overhaul need is confirmed.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    what is an expert in overhauling EFI engines? EFI is just a different carburation technique, And before opening the engine to bits - check the health of the engine then spend wisely to repair only what is necessary. 90% of the times its cylinder head work.
    Feb 2009
    19
    6,107
    5
    49 Post(s)
    There is a strange noise coming from the engine like 'Tuk tuk tuk' continuously,it disappear's once the car is moving or is reved and reappears when the foot is taken of the accelerator.
    Can you please help me identify the problem?
    A mechanic told me that one of the piston is bent thus the noise comes
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    If your piston were bent, you would have a dead engine, if the conrod were bent you would have an extremely noisy 3 cyl engine as the 4th would not fire correctly.
    Ticking is usually head work required, the rocker shaft or one arm of the exhaust rockers must have fractured. Lower block noise is never a tick, its more of a deep rumble with high frequency as the crank rpm is double the cam rpm.
    Feb 2009
    19
    6,107
    5
    49 Post(s)
    Thumbs up
    So basically it's head work?
    Like I would need to change the rings and all.
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    ^^are the rings in head???
    head work means valves,guides,seals etc etc etc head facing.
    ''Peace is an unstable equilibrium,that can only be preserved by acknowledged supremacy and...equal power.'' ''We give up the fort when there is not a man left to defend it.''
    Feb 2009
    19
    6,107
    5
    49 Post(s)
    Quote Originally Posted by immad100 View Post
    Oh sorry
    Can anyone give an estimate of how much it'd cost?
    Feb 2009
    19
    6,107
    5
    49 Post(s)
    BTW,
    I just checked and the highlighted part is somewhat true.
    The car's engine makes wayy more noise then other santros.The throttle body is also faulty.
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    @poster general overhaul costs around 24k these days.
    rings+complete head job costs around 10-11k
  12. #12
    Feb 2009
    19
    6,107
    5
    49 Post(s)
    Thank you.
  13. #13
    attabros's Avatar
    Feb 2012
    37
    May be its a sound of loose belt.
    I to face gar gar sound without accelerating.
    I tighten my engine belt & AC belt.
    The sound goes.
  14. #14
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    ^^^you dug the thread gentle man.
  15. #15
    ToxicDevil's Avatar
    Nov 2010
    1,318
    15 Post(s)
    13
    And I once got an estimate of 60k for overhaul!!!!
  16. #16
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    ^^^ the guy must be kidding ya. hahahaha..
  17. #17
    Feb 2009
    19
    6,107
    5
    49 Post(s)
    I got the same estimate as Toxicdevil.
    My dad had a talk with the mechanic and he came down to 35k-40k
  18. #18
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    ^^^^40k for general overhaul u paid? oh shi* mannnnnn.......
    congrats u are being ripped off.
    max kharcha is 29k these days yes yes max including labour.
  19. #19
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    do remember its g4hc rebuild not sr20DET.
  20. #20
    dr3vil's Avatar
    May 2009
    11,930
    11
    201 Post(s)
    7 Thread(s)
    sWAp better option
    Hanjiii Kaa Storeey Eehh !
