Results 1 to 5 of 5
Thread: suggest oil for Santro that consumes oil a little
    rizkhan2010's Avatar
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    Default suggest oil for Santro that consumes oil a little
    whats the best oil for a 2005 santro that consumes a lil oil...say 0.5L to 0.75L maximum per 1000km .....its 83k driven. fuel economy is good...was using Shell Helix 15W-40 (yellow packing) ....changed oil 2 days ago Shell Helix 20W-50 (red packing). are there any mechanical consequences for thickening the oil grade by 5 degrees?? looking forward to ur comments
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    and its a CNG car
    aqs29's Avatar
    Mar 2006
    Hyderabad
    3,129
    16 Post(s)
    Thick oil grade means more viscosity for the oil. Get ur car's ring/piston checked. Chk for smoke from tail pipe, it is a sign of weak engine.
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    the oil consumption is well within the normal range ...my question is regarding increasing the viscosity of oil...what possible effect it might have on the engine parts/ performance etc...(i increased it from 15W-40 to 20W-50)
    Baloch14's Avatar
    Dec 2011
    Rawalpindi
    Thumbs up
    If mileages of ur sentro are less than 100000 km then you should use Zic Hi flo it is best for sentro I have 2004 and using it. In start the car will give little bit smoke after 50 km smoke will stop. Reason of smoke is it remove the carbon from engine
