Results 1 to 4 of 4
Thread: auto gear of spectra needed
    zain8's Avatar
    Dec 2010
    30
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    good luck in finding it, its quite rare and the ones you do find are dead usually. Most failures are related to wiring under the valve body breaking, Then if you keep on driving in slipping mode you eat away the clutch packs as they overheat badly.
  3. 30-12-2011, 03:28 AM
    2c
    Senior PakWheeler
    Reason
    Not needed.
  4. #3
    imran2d's Avatar
    Dec 2011
    Shaikhupura
    172
    Quote Originally Posted by 2c View Post
    contact @spectra for it
    Liked the advice of Mr.Xulfikar, but my Question is what problems you are facing with your automatic transmission, and never replace your tranny with used one as you have no idea how it was used and why it was removed from the vehicle,also if possible check the automatic tranmission fluid level and the colour of the fluid when the vehicle is at normal operatig temperature, the oil colour should be red/pink or slighlty brown but should not smell like burnet toast as if this is the case then clutch disk and brake bands are worn and excessive heat is generated, I will add more after listening to your problem,ask KIA dealer if they can rebuild the gear box with original spares, I know this is a very big and difficult job in pakistan.but never leave the hope, Allah will help you inshAllah.
    Cheers!
  5. #4
    imran2d's Avatar
    Dec 2011
    Shaikhupura
    172
    Liked the advice of Mr.Xulfiqar, but my Question is what problems you are facing with your automatic transmission, and never replace your tranny with used one as you have no idea how it was used and why it was removed from the vehicle,also if possible check the automatic tranmission fluid level and the colour of the fluid when the vehicle is at normal operatig temperature, the oil colour should be red/pink or slighlty brown but should not smell like burnet toast as it this is the case then clutch disk and brake bands are worn and excessive heat is generated, I will add more after listening to your problem,ask KIA dealer if they can rebuild the gear box with original spares, I know this is a very big and difficult job in pakistan.
