Results 1 to 5 of 5
Thread: Problem wid my santro club :(
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    Default Problem wid my santro club
    If i drove the car a few km then stopped, and then i tried to start it back... Then self stucks.
    All lights goes dim when i try to start.
    only solution is to leave it for 15-20 mins and then try,,, it will start.
    PROBLEM SOLVED--WAS DUE TO WEAK BATTERY CELLS--CHANGED THE BATTERY WORKING FINE
    Body kits available for all cars...
    PM for details
    attabros's Avatar
    Feb 2012
    37
    may be there is a problem with your self or generator.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    clean the ground wire from the battery to the transmission.
    ToxicDevil's Avatar
    Nov 2010
    1,317
    15 Post(s)
    13
    Sounds like a battery problem.
    Check the water, charge the battery and clean (the salt) and tighten the terminals of the battery.
    It also helps if you turn off the lights, fan, tape etc while starting.
    madyahmed's Avatar
    May 2009
    Mardan
    24
    678
    i Had the same problem with my suzuki cultus changed da self and its working fine.... do check ur self...
