Results 1 to 10 of 10
Thread: Santro's Radiator Fan
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    Unhappy Santro's Radiator Fan
    I'm posting this thread to ask a solution which is bothering me and my friend
    its a Santro 07 and the problem is that Fan some times Works like it should starts when needle gets to middle but when we floor the car drive fast Fan starts at 75% of the gauge we changed water in Radiator with coolant and Fan though is fine as i took the temp sensors clip out it works like Direct
    but one thing we cant understand its winter and Fan when we drive Rash turns on at 75%
    Santro's parts are not available in Peshawar and we tried to find the Temp sensor but no shop has it
    So any solution is help full plus we are thinking of taking the temp sensor out and cleaning it but we don't know how to take it out pic is attached bellow
    Thanks
    Santros Radiator Fan -370512
    Hanjiii Kaa Storeey Eehh !
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3989 Post(s)
    94 Thread(s)
    6
    bad news if its flaky.. you need that connected, its also the engine coolant sensor.
    HJbutt's Avatar
    Sep 2008
    Rawalpindi
    26
    84
    does it happen that sometimes it does not turn on at all?
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    Thanks for the Replies All
    and we found the solution it was way to easy
    there was a wire runing from a Coil from CNG kit to the sensor blue wire it was loose at the Coil end we tightend it and it works good now turns on at 50% of gauge now
    but now its facing some front suspension problems
    car is running with 13" Nexen 175\60\13 with alloy rims
    and i think we should get the work done and shift to stock size of tires
    Does any one know what is stock size of santro tires
    Morani's Avatar
    Nov 2008
    33
    348
    2 Post(s)
    I don't know about the stock size but lots of people are using 165/65/13 without any problem...
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    165/65 r13 is best size for santro
    Body kits available for all cars...
    PM for details
    Horse_rider's Avatar
    Sep 2009
    30
    1,364
    3 Post(s)
    stock 155/70 R13
    but 165/65 R13 is best for santro.
    현대 애인
    Sep 2009
    30
    1,364
    3 Post(s)
    Mine sometime does not even switched ON, then I have to switched ON the AC, which starts the fan Directly and the temperature needle become normal, It happens only on signals, then i have to keep an eye on the needle when in signals.
    현대 애인
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    Quote Originally Posted by Horse_rider View Post
    sir if ur ride has FF CNg then check that blue wire which goes to switch
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    and it started Again :@
