Results 1 to 7 of 7
Thread: santro suspension problem
    RehanBhatti's Avatar
    Apr 2012
    53
    Default santro suspension problem
    my santro is pulling little left side.recently,its suspension is overhauled completely.alignment guy told me that its left side caster is not ok.denter said that i need to change the whole subframe.experts please tell me how i can fix this problem without changing the whole subframe.
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    i agree with alignment mechanic. he's seen/checked the car, he knows what he's talking about.
    i dont know any history how what happened and what is the cause.
    did yu check height on both sides? , if one side spring is softer than other side's spring, it will lower the car from one side , and probably cause pulling if alignment is ok.
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
    Apr 2012
    53
    Quote Originally Posted by levin View Post
    Thanks for your reply.Sir,both front shock absorbers are changed with new ones.so,stiffness and height is equal on bothside.only left side wheel is little rearward.i think,they called it caster in their term.anyways,alignment guy refered me to denter and denter advised me to change the whole subframe with a new one.
    is it possible that if i shift subframe little forward?then may be caster will be equal on both sides.your suggestions will be highly appreciated.
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    ^^did this got hit?
    ''Peace is an unstable equilibrium,that can only be preserved by acknowledged supremacy and...equal power.'' ''We give up the fort when there is not a man left to defend it.''
    Apr 2012
    53
    Quote Originally Posted by immad100 View Post
    ^^did this got hit?
    i just purchased this car last month.may be previouse owned hit it hard.
    i just want to know that is this possible to shift its subframe little forward or not?
    immad100's Avatar
    Aug 2010
    5,503
    26 Post(s)
    8 Thread(s)
    ^^^^yes it is possible but it wont be too accurate,can be done 95% but not 100%.
    i still remeber i got my previous santro hit and the driving side wheel face the same problem,denter fixed it,i dint feel any problem later.
    Apr 2012
    53
    95% is not bad.do i need to loose both sides subframe bolts to shift it?
