Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By Xulfiqar
Thread: Kia Pride Engine Problem
    usmann93's Avatar
    Jan 2012
    41
    3 Post(s)
    Default Kia Pride Engine Problem
    Hey guys I have some questions to ask, Answers will be appriciated.
    Recently I bought kia pride 1997 and i came to know that engine oil reduces after 200 km drive. last time i checked and it reduces about 2 ltr after driving only 200 km.performance of engine is also decreases and white smokes coming out from silencer.Oil can also be seen on the tip of the silencer.
    So what do you guys think is it the ring problem or the whole engine needs over haul?
    Or any recommendation for mechanic?
    Kindly suggest what could be the possible issue and form where to get the job done.
    Thanks in advance
    usmann93's Avatar
    Jan 2012
    41
    3 Post(s)
    Xulfiqar bhai and other experts please help guys.
    Tabish1's Avatar
    Feb 2007
    3,068
    24 Post(s)
    I think. whole engine!
    Pakistan <3
    Horse_rider's Avatar
    Sep 2009
    30
    1,364
    3 Post(s)
    Not whole engine, compression test reveals the story of the inside engine, that whether it requires seals changing and valve jobs or whole engine.
    Experts will help further.
    현대 애인
    Site Banned Follow
    vyrus's Avatar
    Nov 2009
    25
    1,611
    Rings are shot. Might even be valve seals. do a compression test and then tell us the numbers.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,403
    131
    3990 Post(s)
    94 Thread(s)
    6
    tell us
    what is the engine operating temperature?
    is the compression timing correct? - timing belt
    what is the condition of the spark plugs?
    usmann93's Avatar
    Jan 2012
    41
    3 Post(s)
    All brothers thanks for your prompt reply.I have checked the spark plugs ,plugs are in decent condition and there is no oil there.Engine compression is low and fuel consumption is increased. temperature needle always be at half gauge.
    Tomorrow inshallah its going for complete diagnose and then i will update you brothers whats the problem is?
    supraman2jz's Avatar
    Jun 2008
    33
    2,700
    76 Post(s)
    Update?
    usmann93's Avatar
    Jan 2012
    41
    3 Post(s)
    Quote Originally Posted by supraman2jz View Post
    Update?
    Sorry for the late reply,rings needs the replacement and yes valves seals as well,so got the job done and now its almost 18 months running perfectly fine after that.
    Jun 2008
    33
    2,700
    76 Post(s)
    May I know where you got it done from?
    Sent from my JY-G2
    "Being between arabs, you call it "Jimmss Yukaan Sagheer", or GMC yukon." - Xulfiqar.
    usmann93's Avatar
    Jan 2012
    41
    3 Post(s)
    No problem brother Panorama Autos DHA phase 2 ext,mechanic name is bakhtiar.Do you also own a kia?
  12. #12
    Jun 2008
    33
    2,700
    76 Post(s)
    A friend owns one, it was a messed up car, bad engine, rust, no suspension, no brakes, nothing electrical worked, etc. He got his engine overhauled from DHA phase II, by some diesel mechanic located next to his residence but that mechanic could never understand the faults. He has already spent somewhere around 50,000 bucks on the overhaul and the little faults that appeared after the overhaul. It still does not run perfect. Only runs fine on CNG and very rich, jerky and unresponsive when turned to petrol. He's gotten crazy with the problems he's facing, though he does agree that he made a mistake tking the car to a diesel mechanic.
    Can you please PM me the details of Mr. Bakhtiar?
  13. #13
    usmann93's Avatar
    Jan 2012
    41
    3 Post(s)
    Bro I have provided you the details I have of the mechanic ,the workshop is near to the tak speed shop.and after the engine overhaul kabhi jana hi nhi hua because engine is working perfectly fine till now.
    I will try to find his contact no but i think I lost it and if you have any other queries than let me know I will be more than happy to help you out.
  14. #14
    Jun 2008
    33
    2,700
    76 Post(s)
    Alrite thanks man, will check out Panorama Autos.
  15. #15
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,403
    131
    3990 Post(s)
    94 Thread(s)
    6
    Its a dead simple mazda 1.1 litre - whats the big deal, anyone who can repair a generic toyota corolla 2E can repair this with even less tools.
  16. #16
    Jun 2008
    33
    2,700
    76 Post(s)
    Yes it's a very good engine, have read about it enough to convince the guy to not sell his car for chump change. Instead told him to get it overhauled and slowly build up the car. It pulls great, better than any Khyber or a plain jane Charade. Sounds good too. His mistake was getting it overhauled by a diesel mechanic.
    @Xulfiqar BTW, went to Abdul Hameed & sons, met Afzaal, gem of a person, he gave his regards for you.. and yes, had lots of chae. Closing time he saved the last cup of tea for me, very kind of him.
    I finally convinced him to lower my car a little, at first he was adament that it would get stiff and all that, then after seeing my persistant determination and some buttering, he gave in
