Results 1 to 12 of 12
Thread: santro weak compressor
    ali_noor's Avatar
    Oct 2010
    214
    Default santro weak compressor
    i have 04 santro exec with orignaly fitted halla compressor,the problem is it didn't cool much when car stops,while driving its cooling is better but not chilling,i have recently serviced the AC but problem seems to be with compressor,please guide me which is good compressor for santro,should i go 4 original one which cost me 20k or go for kabli or any other brand which can be fitted without any modification and gives satisfactory result,please share ur experience and also recomend me any good car ac mechanic who can install it ,im from lahore
    iamadee's Avatar
    Mar 2008
    41
    1,827
    22 Post(s)
    I will not recommend original compressor as it puts a lot of load on the engine though the cooling is great, try finding some alternative compressor fro bilal gunj....
    a person here at forums quoted that he had installed the comp of Daihatsu Boon and was pretty satified with his performance the price tag was around 4k i guess....
    Sharing is caring....
    Bindas353's Avatar
    Jul 2008
    32
    540
    hmm visit first Raza auto care centre may b compresor z not a prblm
    03008471844 free mai checkup krwa lo kia pata sasta kam ho jay u ka
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    before condenming the compressor ensure that the fan responsible for cooling the condenser is in good condition and if any shrouds are missing or leaking air.
    The other part is check the system working pressure and make sure the correct amount of gas is in the unit - overcharging causes loss of cooling too specially when idling because the condenser gets very very hot.
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    Change to Mitubishi's compressor. Its rotary type, dont puts load on engine and cooling is awsum
    Body kits available for all cars...
    PM for details
    ali_imdad's Avatar
    May 2011
    47
    assalam o alaikum
    my charade has a.c in working is chilling but when i switched to a.c car become jam and compressor become very hot when i open bonnet its sometime gives smoke
    is this problem of compressor or what???
    how much it cost i want to repair or installed new???
    waqasjamil's Avatar
    Aug 2006
    189
    4 Post(s)
    I also had same prob as wid Mr.ali_noor. My santro had same issue.
    Its compressor had leaked seals and i got it repaired but after repairing it didnt worked like chilling and at rest there was no cooling at all.
    My mechanic told that compressor needs to be changed. But original is very costly.
    waqasjamil's Avatar
    Aug 2006
    189
    4 Post(s)
    Quote Originally Posted by iamadee View Post
    Why the original one put load on car.? I asked mechanics and they said that if you put sanden then it will put more load but original Halla will not.
    waqasjamil's Avatar
    Aug 2006
    189
    4 Post(s)
    Hello PW! I want to add update to this thread. I had weak compressor in my santro as i mentioned before.
    Today i went to Coolsun car A/C and they told that they will fit Toyota Duet compressor in it. They said original one is costly and made in china.
    So, I installed the Duet compressor. It was bolt on fitting with alteration in piping only. After installation two things i noticed very good in car.
    1. Absolutely no or very minimal load on engine. Car runs on A/C as running with A/C off.
    2. Cooling is awesome and no noise of on/off of compressor.
    I will update how the A/C works in next coming days as it is first day.
    cruzee's Avatar
    Aug 2010
    227
    8 Post(s)
    Yes, i installed Duet comp in my santro and i am very satisfied with its result, no load on engine, cooling is excellent, make sure it available in good condition & guaranteed, a shop in bilal gunj market in basement, don't know its name, but its specialized in all car A/C stuffs.
    There's no car like Mercedes-Benz.
    thedjs's Avatar
    Dec 2012
    i hve santro 2004 wen start AC the compressor puts load on engine and cooling isnt upto mark...
    wt u guys suggest is compressor which is weak or i need to get ac serviced...
    and pls do reply abwt the cost of putting Toyota duet compressor as alot members here recommending it PLS reply ASAP
  12. #12
    ahsan.ahsan12's Avatar
    Jul 2014
    5
    Whats the current status of ur car's ac?
