Results 1 to 4 of 4
Thread: Santro Plus 2002 Power loss while shifting
    zeeshanhaiderr's Avatar
    Jan 2009
    37
    7
    Question Santro Plus 2002 Power loss while shifting
    I have a santro plus 2002 model which is in as much outstanding condition as it can be but there is some serious problem with it. It looses power as soon as i shift into higher gear, like from 1st to 2nd and so on. seems like a power delay. tries to catch up later on but it takes almost 4 to 5 second, some times even more and if you are heading towards a bridge, not a good idea. it wouldnt even move. The stuff i have done so far.
    got plugs, air and oil filter changed along with oil.
    throttle body service along with air intake, and sensors, and maf.
    timing belt, bearing changed.
    fuel pump changed.
    injectors cleaned.
    Car never had a cng installation. its on petrol and gives 7km per litter with ac. i took it to yasin(Allah hoo chowk), Magic motors (model town) and hyundai dealership but all in vein. this thread is last hope, if i cant get it fixed, i will sell it. thank you all for your time and comments.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    since last rains or rains before did you got the wheel bearings checked / replaced.
    D.I.Y - lift each wheel one by one on jack rotate and see it stops by-friction at end-of-momentum.
    Seems like all 4 wheel bearings need change
    How about transmission Oil when did you topped it?
    Clutch - well That may be culprit but then problem will be in all 5 and fuel consumption will also be high
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    dms664's Avatar
    Dec 2007
    Select City
    33
    7,013
    90 Post(s)
    8 Thread(s)
    Get the clutch plate checked.
    My dear ALLAH when I loose hope, help me to remember that Your love is greater than my disappointment and Your plans for my life are better than my Dreams.
    khyber95's Avatar
    Oct 2011
    Hari pur
    33
    802
    2 Post(s)
    Quote Originally Posted by dms664 View Post
    check it first
Tags for this Thread
