Results 1 to 5 of 5
Thread: Santro - Sound from Gear - Urgent
    yadishali's Avatar
    Jun 2012
    21
    Default Santro - Sound from Gear - Urgent
    Dear Fellows,
    Need your urgent help.
    My Santro has very annoying and loud voice from gear. Through gear is smooth in switching but sound keep coming on first, second and third gear and natural. However, sound disappear when I press the clutch or move the car in fourth gear.
    My mechanic told me that it is due to faulty Clutch Bearing and Clutch/Pressure plate. He changed both today but this didn't fix the problem. Now, he said Gear Box is faulty and should be changed as repair will not fix it.
    I am now totally confused what should I do.
    Please help...
    Thanks,
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    It is due to faulty bearing of input or counter shaft.Get the gear box opened and replaced faulty bearings.
    Never loose hope in life,every step gives u something.
    atharhasan's Avatar
    Sep 2009
    36
    48
    dear first top up the gear oil......
    get the gear seal checked if it is not leaking.....
    i changed the gear seal of my santro exec 2004 and next morning there was a sound of something friction...... i went to my mechanic and he simply just topped uped the oil the sound was vanish....
    there is another problem and that is a HMMMMM sound when i drive in over RPM mode means when i drive the car at 40km nin 2nd grear the sound starts and as soon i shift the gear it disappears.... again at 60km in 3rd gear again it starts....
    anyone can help ...... i am thinking to get checked the wheel bearing....
    athar hasan
    03337866862
    yadishali's Avatar
    Jun 2012
    21
    You are absolutely right. Problem was only "low gear oil". I wasted lots of money for opening gear box and fooled by mechanics.
    Quote Originally Posted by atharhasan View Post
    Angel_dust's Avatar
    Feb 2009
    37
    6
    The mechanic has replaced clutch and pressure plate n clutch bearing. I believe he must have checked transmission oil. If not, check it. Is it like a little knocking sound (like tak tak tak)???? And it disappears when clutch is depressed? If these are the symptoms change the top bearing of ur transmission (gear box).
Tags for this Thread
