Results 1 to 4 of 4
Thread: Kia Spectra Engine replacement
    khawar114d's Avatar
    Apr 2009
    Multan
    32
    16
    Default Kia Spectra Engine replacement
    Hi All,
    I need to replace the engine of my KIA spectra. Kindly suggest which engine would serve the purpose best from your experience.....
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    look around for a mazda carb or an EFI (EFI engine with wiring & ECU) it will be a BOLT-ON with no Cut-weld required as KIA is producing cars under Mazda & umbrella. - any other engine swap will not be economical in terms of swap as major cut & weld will be required while car VALUE will remain unchanged
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    syahya's Avatar
    May 2009
    37
    144
    I have Spectra 2003, my car was having some engine problem, I have planned to swap this engine with 4A-FE,
    details are
    Fuel: EFI
    Make : Toyota (Indus Corolla GLi Japanese)
    Capacity : 1600 CC
    Good average on Petrol/CNG (as compared Original spectra engine)
    Parts are easily available
    Spectra original engine is 1500 CC
    But I solved my all Engine issues. Now its running superb on original engine
    khawar114d's Avatar
    Apr 2009
    Multan
    32
    16
    Hi,
    After engine replacement, did u find any issues related to vibrations in car at high speed etc. Because i receive some comments of possible vibrations in car after such modification
