Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Naweed
Thread: Santro 2003 decreasing water in radiator
    shahbaz5's Avatar
    Oct 2010
    7
    Default Santro 2003 decreasing water in radiator
    aoa
    i have santro club 2003. i have observed dat every morning i have to add about half a cup of water to radiator to top it up. i suspected leakage from radiator so got it flushed and checked for leaks. found a minor leak n got it sealed but still the problem persists. engine is too good, no loss of power, car is excellent in every other aspect. somebody suggested that there might b a problem with gasket....need expert opinion.no oil mixed in radiator, no bubbles .....wat might be the problem n how to get it rectified???
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    Quote Originally Posted by shahbaz5 View Post
    aoa
    .. radiator cap has a spring loaded pressure release sys .. either this is not functional
    .. or you don't have a water bottle and a pipe attached to it
    .. or your pipeline is leak
    "You have not lived today until you have done something for someone who can never repay you."
    rizkhan2010's Avatar
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    Quote Originally Posted by Naweed View Post
    +1
    on first & 3rd diagnosis. bad radiator-cap is mostly the cause for minor loss of water like this case.
    By the way, sometimes the escape of water/coolant from cooling system can really make one's head go nuts.
    I am facing an identical situation. I serviced my radiator, changed radiator cap, however, everyday there is still some loss of water (half a glass) from the reservoir bottle. Car is running fine, good economy, no oil trace in radiator, no smoke from exhaust except minor smoke for a few minutes during cold starts in harsh winters (december/ january). The loss of water remains unaccounted for.
    shahbaz5's Avatar
    Oct 2010
    7
    thnz Naweed and rizkhan2010
    i have a water bottle and a pipe attached to ot
    pipeline is not leak
    i think radiator cap n its spring is fine but would still get it changed
    thnx guys. hope it solves the problem
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    Get a good quality radiator-cap. DO NOT buy a second hand piece from junkyard, no matter what. Original Santro Club's radiator-cap is available at around Rs. 400~500.
    noorkhan01's Avatar
    Mar 2011
    Peshawar
    18
    hey dude i was having the same problem with vxr 04 i showed it to the mechanic he then adjusted the tapitts and problem solved... hope it help u too
