Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By aorish
Thread: Santro 2003 reducing oil on long drives
    shahbaz5's Avatar
    Oct 2010
    7
    Default Santro 2003 reducing oil on long drives
    aoa!
    i have a santro club 2003, i hv observed it has reduced some oil when i took a trip to rwp from peshawar and back. i didnt expect it as the engine is in really good condition, i drive normally at 140 km/h on cng on motorway and the car goes easily to 155-160 km/h on petrol. has no other issue....can anyone suggest some remedial measures???
    2ndly i have heard about sajjad motors somewhere in lahore, i have to go to lahore today n if it happens again i m thinking of getting it checked from somewhere in lahore. can anyone pls tell me the loc and/or contact number of this sajjad motors or some other good workshop for santro in lahore.
    regards
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    Reducing a little bit oil is normal for santro
    Body kits available for all cars...
    PM for details
    shahbaz5's Avatar
    Oct 2010
    7
    @aqibbasit
    y is it normal???
    n reducing oil on a travel of 500 kms only....! is dat normal???
    smartdevil_striker's Avatar
    Dec 2006
    30
    3,359
    8
    109 Post(s)
    2 Thread(s)
    No it is not normal...
    First check for any leaks then check rings...
    Platinum&Iridium Plugs,Performance 8MM Wires,Automotive Bulbs and Bosch Horns for sale Contact: 0333-3035482
    rizkhan2010's Avatar
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    define SOME OIL.
    high speed driving may result in oil reduction. Normal acceptable reduction range is upto 1 liter per 1000 km of drive. Keep topping it up as and when oil level is reduced, but do not overfill.
    However, agar tassali na ho tau you better check for external and internal leakage before throwing money to workshops for mini or major overhauls.
    aorish's Avatar
    Aug 2010
    26
    93
    5 Post(s)
    Dont check the oil just after driving when engine is hot..Allow some time to let the oil come down in the pan..Then check the oil level...Best way is to check in the morning before starting the engine
    If u have enemies---GOOD---It means u stood up for something!!!!
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    Quote Originally Posted by shahbaz5 View Post
    @aqibbasit
    y is it normal???
    U have not mentioned the quantity of oil reduced. it is normal for santro to reduce a certain quantity of oil after running
    PM for details
