Results 1 to 10 of 10
Like Tree2Likes
  • 2 Post By dr3vil
Thread: Santro engine gets off while clutch is pressed on CNG
    syedmohsin2k2's Avatar
    Jan 2009
    31
    66
    Default Santro engine gets off while clutch is pressed on CNG
    Dear All...
    my santro engine gets shutdown while applying breaks and shifting to low rpm while pressing clutch. it happen only in cng, not on petrol. Before that it was giving problem of jerks, missing on CNG till speed 20, low RPM. Now when i start the car give race, its fine... but as i try to put car in 1st gear by pressing clutch, the engine gets off, no matter how much race i am giving...
    Its Santro Club, 2003, 70k driven...
    what could be the problem? and solution anyone? help requested.
    usmanuetian's Avatar
    May 2008
    Sharjah
    31
    3,733
    67 Post(s)
    3 Thread(s)
    May b CNG setting problem...
    Leave sooner, drive slower, live longer
    lonewolf1's Avatar
    Jun 2011
    248
    4 Post(s)
    @usmanuetian I have the same issue on my carb cultus. Did you find the problem? My car doesnt shut off but the rpm hovers at 200.
    May 2008
    Sharjah
    31
    3,733
    67 Post(s)
    3 Thread(s)
    I had same problem with my cuore few months ago
    and it was only a cng setting problem
    dr3vil's Avatar
    May 2009
    11,929
    11
    201 Post(s)
    7 Thread(s)
    in desi words
    CNG pe race kam hai !
    Hanjiii Kaa Storeey Eehh !
    faisal911's Avatar
    Mar 2008
    30
    58
    just change plugs
    autohead's Avatar
    Aug 2011
    50
    2 Post(s)
    cng tuning problem
    beep beep.............
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    Set the idle speed from CNG kit
    Body kits available for all cars...
    PM for details
    aqibasit's Avatar
    Apr 2008
    3,178
    30 Post(s)
    2 Thread(s)
    Quote Originally Posted by faisal911 View Post
    just change plugs
    Kya hogya bhai khair to hai ?
    PM for details
    khu84's Avatar
    Nov 2007
    Rawalpindi
    32
    45
    I myself own and use Santro on daily bases. As i had purchased it as used, it was not in good shape so I had faced this one and few other problems which are related. But as got used to this car, got worked on it by different mechanics trying different stuff, things are much better now. One single thing won't solve this problem, you would have to go through a checklist which include following.
    1. Very first thing, get your CNG kit serviced and get any oil removed from cylinder or kit.
    2. In engine compartment the box in which air filter is fixed/installed, make sure it closes properly and is not broken in anyway. Also its properly closed via clips not using small screws. Some mechanics install these screws which clip break or something so check that.
    3. Their is rubber pipe with that air filter box, make sure its also closed in all ends and there is no way for extra air to in. Specially on right side a rectangle type opening on it, it must have a plastic going in from here, should not be open for air. Also make sure this pipe is not torn at any place.
    4. Inside the above mentioned pipe, where it connects to air filter box, normally their is round ring inside, to narrow the pipe, to slow decrease the air going inside, check if its still in there, and no mechanic have removed it.
    5. If problem still remains get you car sensors checked and get them reset.
    6. I also noticed on some CNG stations' gas your car runs better than others, find one and stick to it.
    These are just input from me based on personal experience, someone could add stuff and correct me if anything is off.
Tags for this Thread
