Results 1 to 3 of 3
Thread: Santro Problem (Engine turns off) on CNG
    syedmohsin2k2's Avatar
    Jan 2009
    31
    66
    Default Santro Problem (Engine turns off) on CNG
    Dear All,
    You are all requested to read my problem posted at:
    https://www.pakwheels.com/forums/cng...ng#post3682629
    Kindly give a solution for this. your expert opinion is requested
    "Dear All...
    my santro engine gets shutdown while applying breaks and shifting to low rpm while pressing clutch. it happen only in cng, not on petrol. Before that it was giving problem of jerks, missing on CNG till speed 20, low RPM. Now when i start the car give race, its fine... but as i try to put car in 1st gear by pressing clutch, the engine gets off, no matter how much race i am giving...
    Its Santro Club, 2003, 70k driven...
    what could be the problem? and solution anyone? help requested."
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    It may be because of faulty spark plug cable or defective conversion switch,get it checked accordingly.
    Never loose hope in life,every step gives u something.
    IHateRollas's Avatar
    Jul 2011
    475
    I am also facing same issue but only when cruising down from high speed. When i press clutch to shift down, engine shuts
Tags for this Thread
