Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Like Tree2Likes
Thread: Urgent Help Required Hyundai Santro Idling Issue
    sunny234's Avatar
    Aug 2005
    29
    6,976
    7 Post(s)
    2 Thread(s)
    Default Urgent Help Required Hyundai Santro Idling Issue
    Asalam o Alaikum,
    History of Car:
    1st hand model 2005 with around 60000 kms on the odo. throttle body cleaned by hyundai at 25000km and then again at 55000 kms. last oil, filter and plug change was at 58000 kms.
    Problem:
    The car has an idle issue mainly on petrol. As soon as i lift my foot of the accelerator when the car is idling it shuts down. if i keep my foot on the accelerator it doesn't but despite my foot being on the pedal the rpm still fluctuates a bit however the car doesn't shut itself down. Before this problem occurred it was having a minutely unstable rpm with an issue that when the a/c was switched on the car didn't gain enough revs to keep it own and it would switch on and off with a tick sound many times. Also many times when teh car is moving and i am revving the engine a bit it would switch off and then switch on again as the revs came a bit down.
    On cng the car is pretty much smooth and a slightly turbulent idle is observed but the car never shuts down.
    Diagnosis by local mechanics:
    got the car scanned through hyundai and no error codes were found.
    got it checked by two mechanics and they said that the IACV is gone and both the idle and a/c issues are due to it. moreover i also observed that at times the iacv motor produces a whine that is pretty audible.
    Now the problem is that i want your opinions that whether it is a iacv issue or throttle body can be the culprit. as on many internet forums i have read that the symptoms of both are almost similar. i am willing to change either but not by hit and trial as i mentioned that both the things are still stock.
    I would really appreciate feedback and diagnosis with the limited info provided by me.
    Xulfiqar and other members with an insight and experience with such issues your response is required as tomorrow is a holiday and i am thinking to get the car fixed.
    sunny234's Avatar
    Aug 2005
    29
    6,976
    7 Post(s)
    2 Thread(s)
    anyone to help guys.
    ToxicDevil's Avatar
    Nov 2010
    1,318
    15 Post(s)
    13
    I also think that it is IACV issue.
    eDIT: Or TPS is not set properly.
    sunny234's Avatar
    Aug 2005
    29
    6,976
    7 Post(s)
    2 Thread(s)
    thanks for the help. any idea whether hyundai people offer tps calibration.
    ngen's Avatar
    Oct 2008
    38
    166
    you rarely need to calibrate the tps.
    to manually check if your IACV is working or not : start the car and let it idle. remove the IACV connector and see if there is difference in rpm. then plug the connecter back in and see if there is difference.
    If there is a difference in rpm then your IACV is working ... if not then firstly open up the IACV to see if the valve is stuck... apply carb cleaner and fit everything back ... then do the manual test again... if it still doesn't work then replace the IACV.
    sunny234's Avatar
    Aug 2005
    29
    6,976
    7 Post(s)
    2 Thread(s)
    Update:
    Today fitted an IACV from a friend's santro and the problem persists on petrol. on cng the car is still fine.
    this is getting more confusing.
    Xulfiqar need your help here.
    ngen's Avatar
    Oct 2008
    38
    166
    when you removed the IACV you must have seen a small metal piece ... did you check to see if it rotates smoothly? it is important that it rotates smoothly.
    if its all good then have you ever got your map sensor cleaned? if not try it ... or try your friends sensor on your car while you wait for Xulfiqar bhai to answer. Also check for any air leaks.
    sunny234's Avatar
    Aug 2005
    29
    6,976
    7 Post(s)
    2 Thread(s)
    @ngen
    never saw hyundai people cleaning the map sensor. all they did the last time was take of throttle body clean and re-install it. they also checked iacv and said it was clean.
    also just an hour ago got the car scanned again and no error codes came up.
    now i am looking at the throttle body possibility. will get it checked.
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Did you block the air intake?If yes,then remove it.
    Never loose hope in life,every step gives u something.
    sunny234's Avatar
    Aug 2005
    29
    6,976
    7 Post(s)
    2 Thread(s)
    well the air intake is not blocked.
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    It could be because of bed fuel injector,get it cleaned or checked properly.
  12. #12
    IHateRollas's Avatar
    Jul 2011
    475
    if thing problem is not on CNG the both throttle body and iacv is ok.
    Check for injectors
  13. #13
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    Injectors or fuel rail pressure issue. does it feel retarded to accelerate, pick up in general?
    Keep a cool head and wear seatbelts!
  14. #14
    sunny234's Avatar
    Aug 2005
    29
    6,976
    7 Post(s)
    2 Thread(s)
    @spectra
    the pick up of car is still good. as i drive it on petrol regularly i am sure that pick up is still the same. also mileage ranges between 12-13km/l on petrol.
  15. #15
    sunny234's Avatar
    Aug 2005
    29
    6,976
    7 Post(s)
    2 Thread(s)
    today's update:
    got the throttle body opened and checked for any air leaks or play in the butterfly but NIL.
    tried another new IACV on the car and still improper idle.
    this is hell.
  16. #16
    talhabinomar's Avatar
    May 2011
    26
    2,472
    38 Post(s)
    My santro is giving max 16km/litre
  17. #17
    sunny234's Avatar
    Aug 2005
    29
    6,976
    7 Post(s)
    2 Thread(s)
    if that mileage is within city its very good.
  18. #18
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    @sunny234
    any updates on the problem .. if resolved please give the details of fault .. a friend also facing similar issue for sometime plus the fact that sometimes idle rpm go high as well like 2000 ... i'm opening a new thread as well as the requirement to rectify has suddenly become urgent
    "You have not lived today until you have done something for someone who can never repay you."
  19. #19
    faacs's Avatar
    Dec 2010
    11
    Quote Originally Posted by sunny234 View Post
    today's update:
    this is hell.
    Any update on the issue, i m facing it from last one year. got no solution so far. mechanic saying line behind injectors are not working as there was no patrol coming out of two injectors. they replaced their position, this time again no patrol emitted on 1 & 3.
    Please help
  20. #20
    ngen's Avatar
    Oct 2008
    38
    166
    try replacing cam sensor.
