Results 1 to 15 of 15
Thread: santro CNG Connections
    mukhtar_ali's Avatar
    Jan 2006
    43
    139
    Default santro CNG Connections
    Can any expert tell me color coding of wires of lendi cng kit?
    Also i want to restore wiring of my recently bought santro exec by removing poorly installed Saadi CNG kit (w/o emmulator & advancer). Where wiring might have been disturbed/disconnected by that inexperienced CNG Mechanic. (He has removed insulation from almost every sensor)
    why I want to remove kit?
    1. Kit is giving amazing pick and average but AC is not working on low RPM.
    2. Also engine race increases w/o any reason on petrol.
    3. Gas keeps on running for 10-15 seconds after engine is switch off.
    FX86 =>Mehran98=>Santro03=>Baleno04=>City07=>Xli05
    86-01=> 01-04 => 04=07 =>07=08 =>08-11 =>11
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    It is most likely that the mechanic fiddled with the idle adjustment bolt located on the throttle body, while the engine was running on CNG. Get the the idle RPM adjusted while on petrol at about 800. It should be done by a professional, since I think you might mess-up the situtation. Then turn the engine to CNG and try to adjust the idle on the CNG kit. Hopefully your problem will be resolved. It is also worth niticing that the A/C won't work if the engine RPMs go below certain point like ~500RPM....
    Another important thing is, if you have installed the advancer and the mechanic forgot to connect the advancer return wire, the engine RPM on Petrol also increases.....get the connections checked!
    You may contact the following person to properly address your problem:
    Suleman Shahji
    I-10 CNG station, Opposite Suzuki Azim Motors
    0301-5511942
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
    Jan 2006
    43
    139
    thanks. i will consult the reccomended person
    Jan 2006
    43
    139
    While engine running on CNG ,whether Advenacer (MAP) has any role in controling RPM when AC is turned on ?
    spectra's Avatar
    Jul 2005
    40
    19,667
    304 Post(s)
    24 Thread(s)
    no
    MAP or advancer does not have any role to play with idling. Mixture stiings affect idling especially with AC.
    Keep a cool head and wear seatbelts!
    Jan 2006
    43
    139
    can you please locate TPS, MAP/MAF and Electronic Calculator for me?
    Jan 2006
    43
    139
    I would like to know where MAP/MAF and TPS are located in Santro
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    upload pics of the engine bay......
    Adnan's
    Jan 2006
    43
    139
    santro CNG Connections -652769
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    santro CNG Connections -652785
    Adnan's
    Jan 2006
    43
    139
    thanks test driver. Are u sure this is the MAP. Some one on other discussion forum regarding spectra said that this is ISA Sensor.
  12. #12
    Jan 2006
    43
    139
    two wires are connected to TPS you mentioned and other two yellow/blue are connected to sensor which I mentioned in the pic
    santro CNG Connections -652786
  13. #13
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Dear, see the updated picture! I haven't got first hand experience with santro, but these sensors can surely be identified by physical examination.....
    Adnan's
  14. #14
    Jan 2006
    43
    139
    thanks for quick response, IAC you mentioned is used for air intake/mixing.
  15. #15
    Jan 2006
    43
    139
    Thanks to all of those who helped me. I have resolved the AC tripping problem and pick issue. www.zetronica.com was also very helpful in this issue.
