Results 1 to 4 of 4
Thread: Santro idle rpm issue
    amushtaq's Avatar
    Jan 2012
    12
    Default Santro idle rpm issue
    Hello, I have Santro 2004 model. The car runs fine on CNG but it has following issues on petrol
    * idl rpm drops - When started in morning on petrol it drops rpm when idling, seems like engine is going to shut but the rpms come back up again. rpm drop happens once in like 5 seconds when idling.
    * Low pick and slight missing in 2nd gear - Have to accelerate slowly in 2nd gear.
    I have got the car checked and replaced the fuel pump, fuel filter, got the fuel injectors ultrsonically cleaned, fuel lines cleaned etc. the performance is better after these changes but still not upto the mark. The car runs perfect on CNG. Looking forward to your suggestions.
    Asif
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Get the advancer checked.
    Never loose hope in life,every step gives u something.
    amushtaq's Avatar
    Jan 2012
    12
    Thanks argtr65. Have already checked by disconnecting it too. Same issue.
    Asif
    talhabinomar's Avatar
    May 2011
    26
    2,471
    38 Post(s)
    Check engine mounting if you feel that there is load on engine in Second Gear
