Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By Xulfiqar
Thread: Santro Rubber pipe/What's this is for?
    DIY_er's Avatar
    Mar 2013
    Ajmer
    65
    Default Santro Rubber pipe/What's this is for?
    Guys what's use of this rubber pipe ?
    FRV opening at about 40 psi, Fuel returning at right side. This pipe is not made for 40 psi as FRV works one way.
    It goes back to intake manifold.
    Santro Rubber pipeWhats this is for? -1147777
    Similar Threads:
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    that is the fuel pressure regulator signal pipe - the intake manifold is under vacuum with closed throttle, in this condition the diaphragm inside the regulator is pulled in to lower fuel pressure - as the engine goes to WOT the vacuum is diminished and the fuel rail sees full setting pressure.
    The pipe only sees vacuum, the 40 psi is inside the rail and pipes before the regulator.
    DIY_er's Avatar
    Mar 2013
    Ajmer
    65
    Thank you Sir
