Results 1 to 4 of 4
Thread: Which engine oil for santro?
    DIY_er's Avatar
    Mar 2013
    Ajmer
    65
    Default Which engine oil for santro?
    Till now I've been using Castrol GTX 20W50 API SL. Car clocked 128K.
    Can I go now for SM or SN grade?
    Usage 20 km everyday congested city condition, occasional highway 300 km plus, AC on/off as per requirement.
    Recently cleaned sludge out of valves here - https://www.pakwheels.com/forums/d-i...enating-santro
    Suggestions please.
    rizkhan2010's Avatar
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    SN, SM all are downward compatible.
    So yes, you can use API - SM or SN for cars that are run on older grades like SL, SJ, or SG etc.
    by the way, for Hyundai Santro try 10w-40, instead of 20w. I hope you will like it.
    DIY_er's Avatar
    Mar 2013
    Ajmer
    65
    OK, so i would flush engine with 3M engine flush and thereafter use SM or SN grade oil.
    Preferably SM as there will be leftover mineral oil in engine and mixing with SM is ok.
    ToxicDevil's Avatar
    Nov 2010
    1,318
    15 Post(s)
    13
    Just use havoline synthetic. There is no problem in mixing synthetic with mineral
